Old 14-09-2014, 08:45 PM   #1
dirty hands
Over Thinker
dirty hands's Avatar
Default ford fiesta man clutch replacement How what ?
someone has asked me to help fit a clutch in a fiesta
done front wheel drives before not a festiva .. only toyotas mitsubishis
what the easiest way to do the job on this Ford
dont have a repair manual -no nice hoist-
so need a how to DIY guide
gearbox out from under
what has to be done for this way
Take the motor and gearbox out
any annoying quirks to doing this
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2014, 05:59 PM   #2
dirty hands
Over Thinker
Default Re: ford fiesta man clutch replacement How what ?
humm
how to on - clutch jobs not coming up in a search
will need a repair manual
Old 15-09-2014, 07:37 PM   #3
dirty hands
Over Thinker
dam its a mazda engine and gearbox ...
clone of the mazda 121 hatch
http://www.ebay.com.au/itm/Mazda-121...item23400e8729
Old 15-09-2014, 07:57 PM   #4
partzkid
should be able to do it from underneath, with the engine supported. you know the have an internal slave cylinder yeah. is it festiva or fiesta?
partzkid is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2014, 03:38 PM   #5
dirty hands
Over Thinker
he tells me its a fiesta -- get to see the car this week - to confirm
internal slave cyl -nope didnt know - you mean inside the bell housing
-whos bright idea was that ?
one repair manual for a fiesta Mark 3 89-95 -300 pages - no gearbox section wow
engine and gearbox remove togeather ---thats it
http://vk.com/doc-50029547_161721090...13b3cd81cf1c0b
Old 21-09-2014, 04:14 PM   #6
dirty hands
Over Thinker
clutch slave not cheap
can come with the whole clutch kit (makes sense)
uses a
a borg and beck Concentric Slave Cylinder for the Ford Fiesta
so If the clutch slave is suspect --the box has to come out - just to replace this part
and slave cyl part is holding the throw out bearing to the clutch -over the input shaft
will do a write up about this job ...if it comes my way
Old 23-09-2014, 01:21 PM   #7
dirty hands
Over Thinker
i went to a wrecker and found a ford fiesta
they removed the manual gearbox from below motor the subframe inplace
gives some hope
Old 27-09-2014, 11:00 AM   #8
oemdenied
box out from underneath leave subframe in place.
OR
if you don't have AC in the car its quicker and easier to drop engine and box out from underneath then split
oemdenied is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2014, 12:40 PM   #9
Bowser22
What model fiesta was it exactly?
SZ TS Territory TDCi '13
WQ LX Fiesta '08
XG Falcon '94
Bowser22 is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2014, 01:00 PM   #10
oemdenied
Shouldn't matter as long as its a fiesta not a festiva out the bottom it needs to come.
Advertising removed.
Old 30-09-2014, 10:23 AM   #11
dirty hands
Over Thinker
found out today - and looked at it for the first time its a 1999 model
getting a battery to test drive it and do diagnostics and compression test
unreg for some reason
how do you bleed the internal master cyl
pretty good shape straight no rust - had a lot of work done
444000 k but not the original motor
gearbox from the bottom will work better for me
looks like
undo the centre brace
drive shafts out
take off gearbox attachments - drop out below - not too bad I would say
no repair manual yet
doing more research
Old 30-09-2014, 11:12 AM   #12
Franco Cozzo
Franco Cozzo's Avatar
It'll be a Festiva, not a Fiesta as we didn't get them in Australia until later.
I've got the genuine shop manual for a WF Festiva, I'm scanning the manual trans removal procedure and I'll link to it up here.
Fluid inspection and replacement:
Old 30-09-2014, 03:37 PM   #13
oemdenied
unlucky :(
the fiesta was such a better car!
good luck with the box swap mate.
Old 30-09-2014, 09:00 PM   #14
dirty hands
Over Thinker
now confirmed --- its a 1999 Ford Festiva Hatchback
a mazda 323 clone
thank you the scanning in of the required parts that is great
Old 30-09-2014, 09:19 PM   #15
mik
mik's Avatar
crikey , that looks like hard yakka, will this need a dual mass flywheel ?
good there job BigDamo.
Old 30-09-2014, 10:00 PM   #16
Franco Cozzo
a mazda 323 clone
Its based on a Mazda platform, built by Kia and sold as a Ford
Depending on engine variant you have, it'll either be a Mazda B3 (1.3L) or B5 (1.5L) engine.
I have one here also, pretty easy to work on lots of room in the engine bay compared to most FWD cars getting around today.
I don't think it would, thats more of a modern thing, these Festivas are quite basic cars but damn they put up with some punishment though, we've had ours since new, 274,000km with missing services its whole life and she still starts up and runs, never had a mechanical failure either.
Old 01-10-2014, 06:43 AM   #17
dirty hands
Over Thinker
yes it has a Kia name on one engine bay tag ---
going to be interesting if the parts guy doesnt know kia -ford -mazda parts
no to fitting a dual mass flywheel --they are trouble (failure rates high)
badges on side of car say its a 1.5 motor
(thank you BigDamo.)
yes plenty of room in the engine bay
yep thats the gearbox alright
didnt know the speedo was the gearbox fill up point
now this forum has festiva information fantastic
this is similar to the car
Old 01-10-2014, 10:47 AM   #18
Franco Cozzo
Yep thats a WF Festiva
Old 31-10-2014, 10:51 PM   #19
mik
mik's Avatar
i like the simple style cars, i just watched a video of bmw clutch job, dual mass the whole bit, crikey , for a clutch job they did have to replace a lot of parts, my mate had a clutch done on bmw mini, for the cost of his clutch repair i could buy half a fiesta or a kia, ive said this before, but if some people new the cost to do repairs/general maintenance on their small economy cars up front......they would not go near them.
