21-01-2015, 02:28 PM | #1 | ||
Anyone no what size the bearing on the ac compresser pully is ?
21-01-2015, 04:53 PM | #2 | ||
Au Falcon = Mr Reliable
Hi Redxr601 & welcome to AFF, i dont know the size of the bearing but if you dismantle your a/c compressor & take the bearing down to a local bearing place they can measure it up & supply one one for you. Good luck!
cheer's, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) |
22-01-2015, 10:24 PM | #4 | ||
Out with the verniers then...
05-02-2015, 12:12 AM | #5 | ||
And does anyone no if a El falcon gearbox will go in my au xr6 series 2?
09-02-2015, 12:50 AM | #6 | |||
Unless someone jumps in here & says "yes", then it may require both gearboxes to be placed on the ground next to each other & compared/measured up. If you're keen on the exchange, get a couple of junk casings/bellhousings & see how they compare. I don't think the engine blocks have changed much, but the "bellhousing to engine" bolt holes may be different, & the gearbox cross mount would be different. Then there's the electronics/speedo to consider. Again, I'm guessing here. |
09-02-2015, 01:13 PM | #7 | ||
Okay thanks I don't know what to do my gearbox slips then u give it a rev or to and it pops in only sometimes tho maybe a oil change will fix it ? Any ideas?
12-02-2015, 12:14 PM | #8 | |||
5.6L x 2 pilot
According to the work shop manuals, both 6 cyl EL and AU run a BTR 93LE tranmission, and both are controlled from the EECV ECU. My guess is that they would fit. Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
