Old 15-02-2015, 12:02 PM   #1
12slots4ever
12slots4ever's Avatar
Default Door protection strip, double sided tape
Behind the door protection strips there is a piece of double sided tape that is 1" or 25mm wide that I assume is to stop dust and dirt from getting behind the strip. My problem is where do I get the 25mm wide double sided tape from? Tried SC & Repco but haven't tried Ford yet, just so used to them not having anything, ever! Any help appreciated. Thanks George
12slots4ever is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2015, 12:24 PM   #2
mcfly94
mcfly94's Avatar
Default Re: Door protection strip, double sided tape
i got mine from autobarn (1" wide stuff), the original tape that is on there is actually only 10mm, i wonder if yours has been changed?
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2015, 12:50 PM   #3
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Possibly:
http://www.bunnings.com.au/3m-scotch...-tape_p3978296
Was just mentioned here:
http://www.fordforums.com.au/showthr...72#post5330872
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2015, 02:40 PM   #4
revcore
revcore's Avatar
I use a thin bead of Sikaflex...works perfectly.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2015, 03:34 PM   #5
Spurious
I bought some automotive double sided tape from a hardware store. Black in colour with green plastic backing.
The stuff would stick a NASA space shuttle to the back of a C130 !!!
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2015, 02:13 PM   #6
12slots4ever
Thank you everyone!!! George.
