Old 22-04-2015, 08:44 PM   #61
AUwindsor
Default Re: Why do cammed ls motors sound and go better?
Originally Posted by GTP-RPD View Post
At the time another big $$ 6L was on Bruce Heinrichs dyno as well, built bottom end, rectangle port L98 heads stuffed full of huge valves & ported heavily, 12.5:1, solid roller cam, FAST intake, dry sump etc etc.
Made 352rwkw & a LOT less through the midrange.....
It is always match the parts, bigger is often not better, everything must work together - airspeed through the heads is critical, big ports suck, the right sized ports win.
spot on. often people who don't understand an engine fall for the hype of the bigger port flow number, the better. this isn't always correct, often otherwise
you can flow a 4" sewer pipe on a bench, it'll flow 1000cfm.. doesn't mean it will make more power, or better yet ET faster in the car.
AUwindsor is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2015, 02:33 PM   #62
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
Each to their own op. I think the Boss sounds the goods with stock cams.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
