Old 22-06-2015, 11:15 PM   #1
WadeST
Old Dog
Default Focus St wheels package
Hi everyone, I am trying to find out if it is possible to fit 17" wheels to the 2012 ST. She who must be obeyed and loved (the missus not the car) says it's just too rough and she just isn't going to wear 2 sports bras every time I want to drive somewhere. In the good ol' USA they seem to be fitting 17's as a snow tyre option. I thought maybe I could run 215/50/17 Pilot3 which have a softer and taller sidewall and please us both. I went to my local Jax and he didn't even bother thinking about it and just said ""no wont fit in there mate". Am I missing something or do the yanks have a smaller brake caliper setup?
WadeST is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2015, 06:47 AM   #2
RACERED
Winding roads please
RACERED's Avatar
Default Re: Focus St wheels package
Go see the local ford dealer to see what they say.. i put michelin 235 40 18s on my st after the f1s and I am happy with em.... sidewall is no different to the f1, great tyre. I just didnt like the noise of the f1. 50 series tyre will help you on a 17
HURRY UP WEEKEND DRIVE
RACERED is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2015, 06:41 PM   #3
gumby123
LW Focus TDCI
I've seen a wrecked ST on ebay (not there now) but they had fitted 17" Sport wheels to it.
The big question would have been whether the brakes will fit inside the smaller wheels, the answer then is "yes".
gumby123 is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2015, 12:39 AM   #4
DJM83
Barra Turbo > V8
DJM83's Avatar
I've seen focus trend wheels in the front of an ST and I'm certain they are 16 inch. IMO your car will look stupid with less than 18 inch wheels but it's your car.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
-2022 Hyundai Tucson Highlander Diesel N Line
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 24-06-2015, 08:11 AM   #5
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
If you go smaller 16" wheels you're going to need to go up on sidewall of the tyre, and it will handle crap when the bigger sidewall flexes as well as being limited by tyre choice.
I've got 205/55R16 on my Focus and I can only get the older performance tyres like ContiSportContact 2.
17s would probably be the go IMO if you certainly want to go a bit more sidewall.
Old 24-06-2015, 10:40 AM   #6
marko
Marko
marko's Avatar
My Mrs doesn't have a problem with the bouncing and she ain't small.
It isn't the tyres, it's the suspension. Got exactly the same tyre/wheel set up on the XR5 and ST and the 5 rides differently.
Sent while boosting ....
May the FORD be with you!
marko is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2015, 08:11 PM   #7
aratic
aratic's Avatar
Yank ST's use the exact same brake setup FYI.
2013 Ford Focus ST
aratic is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2015, 08:57 PM   #8
WadeST
Old Dog
Thanks for that, I had come across some people on forums there talking about a big brake package option so wasn't sure. I certainly wasn't looking at going to 16's that would be too much, but thought a compromise with 17's might work. Thanks everyone.
Old 24-06-2015, 10:33 PM   #9
In Focus
Have you tried running at a slightly lower inflation rate? I run at about 3psi under the recommended amount on the Skoda, and it takes the edge off hard bumps. The wear has been even on my tyres before anyone asks. I'm not saying you should go too low or under-inflate, just been on the lower side if your someone who tends to go high.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
