12-07-2015, 01:49 PM | #1 | ||
AU XR8 Owner
Howdy all
I have managed to pickup a set of S2 front brakes and associated bits for my S1.5 XR8 but am not sure if I need the master cylinder or not. I have the dual booster coming so that side of it's sorted, its just if there is any difference in valving between the S1/1.5 master and the S2. Anyone know? Cheers Bruce
My Current Stock of Fords: 1994 ED Wagon retrofitted with '98 EL equipment 2000 AU1.5 XR8 in Winter White - Ex Police |
12-07-2015, 07:58 PM | #2 | ||
Don't believe the series 2 master or booster is needed but will need s2 sway bar, links, and brackets to go with s2 lower arms with the brake setup.
13-07-2015, 09:53 AM | #3 | ||
AU XR8 Owner
Thanks PJ, will cancel the master. I have everything else as per the thread here so should be good to go
14-07-2015, 03:42 PM | #4 | ||
Spanner Thrower
S1 and S2 Boosters are different. you would have to drill the firewall to make the S2 booster fit. (S1 has a 2 bolt, S2 onwards has a 3 bolt.)
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
