Old 02-10-2015, 09:11 PM   #1
zlcrazy
zlcrazy's Avatar
Default Starting car with headlights on - ok or not?
Hi all
My BA2 XR6 Turbo has auto headlights. Obviously if its set to auto the lights come on as soon as I turn the key to on if its parked in my garage. The question is does this hurt the battery by starting the engine with the headlights on?
Lots of cars do this yes but does it have much effect on the battery or not?
Any info would be much appreciated
2005 BAII Falcon XR6T - Velocity Blue
Factory Options; Sunroof, Premium Sound, Plexus Blue Cloth Trim.
Genuine Accessories; XR Scuff Plates, XR Blue Carpet Mats, Boot Liner, Cargo Net, Aux Audio Input (Boosted Type), Front & Rear Mudflaps, Headlamp Protectors, Bluetooth and Mobile Phone Holder.
[B]2000 AU2 Fairmont Wagon - Congo Green
Factory Smart Bullbar, Hayman Reese Heavy Duty 2300kg Towpack and Front and Rear Mudflaps.
zlcrazy is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2015, 09:28 PM   #2
irish2
Default Re: Starting car with headlights on - ok or not?
It isn't really a problem until your battery is on its' last legs. Then you will get a nice little click noise instead of a slow crank.
irish2 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2015, 09:30 PM   #3
Mechan1k
Mechan1k's Avatar
That .. and that fact that the globes flick on ... off and back on again while cranking.
That sort of current change through the globes can't be good for longevity for them.
Old 02-10-2015, 09:56 PM   #4
LyleXR8
My 05 Vz SS has still got original globes in it and headlights stay on auto
LyleXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2015, 11:27 PM   #5
Ben73
Ben73's Avatar
Ranger headlights delay a few seconds before coming on. So I turn it to ON parking lights come on while I wait for Glowplug light to go off, then I turn it to start. Lights then come on once car is started. Good setup for the auto lights.
Ben73 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2015, 11:42 PM   #6
mik
mik's Avatar
i think along the same lines too, and ive always thought ...... rightly or wrongly that having fluctuating power to electronics even momentarily while cranking, (ecu, various modules,etc) it may be not good for longevity of these items.
Old 03-10-2015, 11:08 PM   #7
RealChampionSup
Our Ba had the head light auto on with the ignition, (telstra standard fitment), used to blow highlights all the time. Found the wire and cut it, don't blow anymore (other then you would expect)
RealChampionSup is offline   Reply With Quote Multi-Quote with this Post
