Old 23-09-2016, 08:10 PM   #91
barnz_xr8
Turbo 358W
barnz_xr8's Avatar
Default Re: $165,000 for new LS9 HSV
probably cheaper to buy a gts sell the LSA for 10 grand and then buy the ls9 for 20 grand usd, and save $65,000 in the process, and HSV should and could do something more interesting than a LS9, take each LSA and strip down, bore and hone the block 5 thou, add a 4 inch stroke callies crank, 4.07 mahle pistons, and some h beam rods, give the lsa heads to yella terra to do a good cnc program to, then add a harrop 2.8l blower and intake, that would add alot of australia components, as i certainly felt some pride knowing from T3 on hot fords had local content.
barnz_xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2016, 10:47 AM   #92
fgpsi
Originally Posted by b0son View Post
Will be interesting to see if they're snapped as quick as the Sprints were. Being the absolute final GTS's, I suspect the GTSR and W1 will be bought as investments by a lot of punters.
They'll sell em quicker than the sprints as they are not half arsed cars
fgpsi is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2016, 10:48 AM   #93
fgpsi
Originally Posted by CyberWasp View Post
Translation.
HSV are releasing the GTS-RU-Kidding.
It will be a limited edition, in that HSV will over quote the actual engine power by more kw's, than any other HSV before it.
Jealousy post
