Old 12-12-2016, 08:44 PM   #1
Rs31markie
Default Oil leak
Hi all, did a oil and filter change at the weekend. Whilst doing this I noticed the rocker cover gasket is leaking, and filling number one coil pack with oil. Is this normal? New gasket is on order, and I'll do it this weekend. Car is a lt zetec '07, with 100k, did a coolant flush at the same time.
Rs31markie is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2016, 07:47 AM   #2
DZFord
DZFord's Avatar
Default Re: Oil leak
Definitely not normal, and yeah, the valve cover gasket replacement should do the trick.
