Hey there,
I have a carter thermoquad 9146s, Can any body tell me what car that is from. Thanks. |
Thermoquads were used as original equipment on mostly Chrysler products from 1971 to 1985.
Read up about thermoquads here ... http://www.carbkitsource.com/carbs/t.../TQ-index.html |
http://www.carbkitsource.com/carbs/t...ges/thermoquad - AUS.html according to this page it is not an OEMl used on the Ford V8s in Australia.
#4 | |||
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
Yeah i new they were on falcons from late 1976 to 1984,
I own a 1978 Fairmont GXL that i have owned since 1987, and i had a XD Fairmont Ghia as well, I can never remember buying a thermoquad, I have been looking at some of my old parts and in particular the carb off my GXL and this is the only one i can find in my shed at the moment, From what i can find out is that the carb off my car should be a 9085s. |
#6 | |||
P6 LTD
More here http://www.fordforums.com.au/showthr...ghlight=carter |
Thanks Paul,
Is there any chance this carb was fitted to my GXL from the factory. |
mortgage free !
Had this carbie on several of my 5.8's including the XC 2 door GXL, they were all as factory fitted.
Also during that period, they were standard on the 351C short motors from factory which were used for final fitout to several De Tomaso's (Pantera's, Longchamp's etc) imported as partially build vehicle and finished/built by a well known Sydney dealer - BUT most quads were removed and replaced with Holley D/Pumpers.
#9 | |||
P6 LTD
Also, as your vehicle is a '78 model, know that the '78 model F100's changed from a Motorcraft to Carter Thermoquad carbies around April/May (IIRC) 1978. In that, the F Series Thermoquads would have been fitted to the F Trucks only. Also know that the F Series Cleveland engines were different in that they had different heads. In that, assembly would have been different too. |
My 12/78 Falcon originally had a Thermoquad from new.
jaydee351 4DV8 |
This car has been in the family since new,
I bought the GXL from my father in 1987, I have had it garaged since 1988, I striped the car down and had it painted and never got around to putting back together, And this is the only carb that i can find, I have kept all the parts together during this time, I was curios about the numbers as they don't match my car? |
My bad, just went to the shed and dug it out, Motorcraft.
jaydee351 4DV8 |
#13 | ||
It will have a Motorcraft tag on it but it wil be a carter thermoquad,
What numbers are on it, The numbers will be on the left rear of the throttle body. |
#14 | ||
Well there you go, I know sheet about these things, it has 9142S stamped and under it
216 8.
jaydee351 4DV8 |
#15 | ||
#16 | |||
AFAIK Thermoquads were fitted to XC Update models onwards Clevelands in Australia? Most people wouldn't recognise them 'cos at the first sign of trouble of an "upgrade" they were replaced with Holleys. |
#17 | ||
Performance moderator
![]() Join Date: Feb 2005
Tmk they where fitted to the black EPA motors.. From XC on ? I had to fit one years back to pass registration on XD chasser. Or go through RTA. EPA test..
#18 | ||
P6 LTD
Carter TQ's were fitted to all Aus Ford Cleveland powered cars (Falcon/Fairmont/Fairlane/LTD/F Series) from 1 July 1976 through to August 1685. Only exception is that of the 1976 through to April 1978 Cleveland powered F Series vehicles.
#19 | ||
mortgage free !
Probably not the case for all the Quads fitted ?, but the resin base was a problem on at least 2 of my 5.8's.
Appears the base would flex slightly ? and when refitted would affect the vacuum reading/tuning between cold n hot running. After replacing with a new base was all good on both occasions, over the years have heard this was experienced by quite a few others who just gave up and fitted Holley's.
#20 | |||
Dr Terry P.S. obviously the 1685 is a typo & should be 1985. |
#21 | ||
Is it true that the 5.8 thermoquads have smaller main jets
compared to the 4.9 to meet emissions. |
#22 | ||
P6 LTD
#23 | |||
P6 LTD
http://www.fordforums.com.au/showthr...t=77535&page=4 F Series build numbers for 1985 are as follows; Total 4x2 F Series - 1224 units F100 - 749 F250 - 36 F350 - 48 F100 XLT pack - 157 Ambulance - 234 4x2 5.8 - 370 units 4x2 4.1 - 299 units 4x2 5.0 - 555 units Total 4x4 F Series - 1827 units F100 - 1041 Bronco - 665 F350 - 12 4x4 5.8 - 427 units 4x4 4.1 - 182 units 4x4 5.0 - 1218 units Engines by monthly production ___________4.1 - 4x2 & 4x4 - 5.0 - 4x2 & 4x4 - 5.8 - 4x2 & 4x4 January__________35 & 2_________12 & 34_________46 & 29 February_________43 & 50________2 & 97__________34 & 70 March___________57 & 20________20 & 78_________67 & 52 April____________21 & 27_________9 & 82__________30 & 69 May_____________67 & 26________8 & 85___________69 & 81 June_____________45 & 18________7 & 67___________52 & 50 July______________31 & 38________15 & 110_________56 & 65 August____________0 & 0_________119 & 149________16 & 11 September_________0 & 1_________131 & 137________0 & 0 October___________0 & 0__________50 & 251_________0 & 0 November_________0 & 0__________122 & 44__________0 & 0 December_________0 & 0__________60 & 84___________0 & 0 |
#24 | |||
Dr Terry |
#25 | ||
So if one was to build a 5.8 engine with mild cam
and replace the main jets with the ones from a 4.9 this would obviously be beneficial to performance. |
#26 | ||
P6 LTD
#27 | |||
From the Mopar guys:
#28 | ||
Remember when I was 18 I had a XC GS 351 4 speed and the roar from those secondary's was just magic.
2018 Mustang GT |
#29 | ||
FG XR6T trayback
#30 | ||
