#31 | ||
Projecta Automatic 12V 6200mA 2 Stage Battery Charger I have
$20 or so off ebay, 2nd hand in excellent condition Does the trick
Before - ED Falcon Futura (sold) EL XR6 (R.I.P.) VX SS (R.I.P) VE Berlina |
#32 | ||
Experienced Member
This was true decades ago when battery cases were made from different materials, these days battery cases are made of plastic which makes your statement a myth these days.
#33 | ||
![]() Join Date: Oct 2006
Probably more than a century ago now. The first lead-acid batteries consisted of glass cells that were enclosed in tar-lined wooden boxes. A damp concrete floor could cause the wood to swell, breaking the glass inside. But it has also been suggested that old hard rubber cased car batteries had cases porous enough that battery acid could seep through it and create a conductive path through the damp concrete, draining the battery.
regards Blue |
#34 | |||
Remember the old pre EFI falcons that had 20 amp alternators. They never blew batteries the way modern cars can.
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
#35 | ||
I get your point but you are a bit out There never were 20 amp alternators.The smallest Lucas or Bosch used in Aust were 35 then 40 then 55 and so on.But does the alternator kill the battery or batteries made of lighter materials that just don't last
#36 | ||
Experienced Member
Your comment is totally wrong, battery will take what amp charge it will need when charging regardless how high of an amp rating of alternator, remember the regulator also decides what charge rate is for the battery when charging.
#37 | ||
#38 | ||
George
![]() Join Date: Jun 2015
Decent ammeter, 530CCA Ford Motorcraft battery and $75 (Bunnings) Projecta 4300mA Automatic Charge/Maintain does the the job for me
BFWSM https://www.fordforums.com.au/vbport...articleid=1708 ![]() R/Up 2019 ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate 1200cc Manual. Last edited by BFIIGhiaZF6; 12-07-2017 at 01:30 PM. |
#39 | |||
I checked this out and went with a 5amp charger : Ctek MXS 5. It came with alligator clips. Plus I got a pack of 3 connectors with eyelet connectors to fit permanently onto battery M6/M8 terminal bolts. Cost about $105, with 20% discount. It seems they've always got a 5,10 or 20% discount. The beauty of Ctek is that it's a system. The plugs can have battery condition indicators, extension leads and panel mount indicators. A mate bought the Bluetooth connector. So within range, he can check battery % charged on his phone. The 3 pack of connectors was only $26. This year I paid $220 at supercheap for a 16A Charger. It got a battery charged again, but swollen at the ends. The battery was 3 years old and unused for 9 months?? I think multiple Ctek chargers is a better option. The Ctek 0.8A would work as a trickle charger for small batteries. then Ctek 3.8A for small & medium. But similar price to the 5.0A. and Ctek 5.0A (mine) which will do small to large SUV batteries, and AGM as well. The Lithium 5.0A is for next generation batteries. This is what you'll need if you've got a Lithium battery. I reckon for maintaining multiple cars, the MXS 5.0 and permanent connector on each car. Then just alternate every week or two between vehicles ( after 10 days on trickle, they cycle back to start) OR An MXS3.8 or 5.0 for each vehicle. |
