Diesel Motor
The clear tail lights on my lv (the inner plastic) has turned yellowish. I've seen this is common with mk2.5 Focii when I look around in town. Does anybody know how can we reach that inside clear plastic (the one with the honeycomb pattern) so I can polish both sides with a headlight restorer kit?
Thanks heaps, RadioactiveX |
Not overly sure that you can except through the small hole that the globe goes in. They are a sealed unit between the two halves so unless you wanted to separate and rejoin I can't see much other option.
Cheers Russ
#3 | |||
Diesel Motor
anyone else have tail lights turned yellow?
yes my LV has turned a yukky yellowish colour
Build Thread: BA XR8 with all the goodies. fordforums.com.au/showthread.php?t=11247663 |
Diesel Motor
Do you have any ideas how to polish the plastic inside?
Sent from my TA-1012 using Tapatalk |
