Hi, I have blown the fusible link and replaced it with a after market link. my question is what amps should it be?
Thanks. |
They range from 120A - 175A dependant on engine.
Cheers Russ
Thanks for the quick reply. I have a diesel so would you go for the 175 amp ?
Thanks again. |
I believe the diesel one (2.0L TDCi) is 150A.
Cheers Russ
Thanks for your help. I’ve put a 150 in and started it 3 times in quick succession and it was ok. Also ran it with lights on hi beam and anything else to check the supply from the alternator and was all ok.
Thanks again👍 |
