I have a 1994 Ford laser 1.6 manual the engine use to cut out then sometimes start up again by dropping down the gears other times had to wait for a while then it would start until now when it cut out and doesn’t want to turn over. The ignition lights come on and can hear fuel pump and turn the key and nothing is there anyone who has had this problem or someone who can help me with this problem?
Similar issue happened to my 93 KH Laser, no spark at lead ends, ended up being the distributor module.
So you best start by checking for spark. Pending on your results will determine next steps. No spark could be module or even coil or connections in the ignition system. Let us know how you go and we can try and work through it. Is it a KH or KJ laser? |
Yep as above
XC GS OLD SCHOOL MUSCLE ![]() Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
Check battery voltage.
Check battery cables. Check starter for power at main cable and switch terminal . check earth cable.bridge power to small wire and see if it turns over. Is coolant level normal. |
So does it turn over alright or is it like the battery is flat and the starter won,t work,or it it turning over alright but just won,t fire. If the former,check battery terminals and starter motor connections,if its the latter the problem is almost certainly the ign module on the distributor.
