15-06-2018, 05:15 PM | #1 | ||
Is there anything I can add to prevent the noise from the reverse light power from causing my rear view camera feed to flicker?
2020.25 Focus SA ST-Line Wagon + DAP 2011 Focus LW Trend (Diesel) [sold] 2006 Territory SY Ghia (AWD) |
15-06-2018, 08:31 PM | #2 | ||
Hi. Burg design in Moorabbin do a filter for reverse cams (part number 25-00F). ( http://www.burgdesign.com.au/ ). Cheers MD
16-06-2018, 06:03 PM | #3 | ||
Is part number 25-002F the thing I need?
16-06-2018, 06:05 PM | #4 | ||
No worries, found what I needed.
22-07-2018, 01:12 AM | #5 | ||
22-07-2018, 01:15 AM | #6 | ||
Hi, the part I bought only helped the problem a little bit and I still get interference. I’m considering getting a voltage regulator which would work much better to smooth out the power. Sorry I couldn’t be of help.
I think the part I bought was really just a fancy capacitor which in theory should work for most applications, it just didn’t work for me.
22-07-2018, 01:24 AM | #7 | ||
ok, thanks for that anyway, I have LED reverse light but don't know if that is the cause or poor quality camera.
Thanks. |
22-07-2018, 09:33 PM | #8 | ||
Over Macho Grande??
How about using the reverse lights to switch a relay that then powers the camera/setup, it would be an alternative way to do it and also a way for testing if that LED's are causing interference. (That also makes it possible to add a button to turn on the reverse camera whenever you like, even when not in reverse)
22-07-2018, 09:56 PM | #9 | |||
Thanks. |
22-07-2018, 10:24 PM | #10 | |||
When fitting LED's into you lighting system ect you MUST also install a LED load resistor on each light feed. For instance, I have all LED rear lights on my ute tray and used Narva's and without these fitted into each feed line they will flicker especially the indicators. I have 3, one for indicators, one for tail lights and one for reverse lights which also provides power to 3 rear cameras. They are spliced into the factory harness and mounted on a alloy plate see bottom left of pic. You can get them from Supercheap. http://www.supercheapauto.com.au/Pro...21-Watt/287170 Last edited by ozrunner; 22-07-2018 at 10:35 PM. |
22-07-2018, 11:47 PM | #11 | ||
These tail lights are not just LED bulbs. They are a whole assembly. They came with 10W rated resistors, quite heavy, for each side. If I leave them unplugged the car gives me a tail light fault warning. With them plugged in, no warning. I might just have to go with the relay option but where can I get power from?
