Old 31-07-2018, 08:12 PM   #1
au350hp
Default Radiator coolant/water ratio?
What % coolant to demineralised water have people had the best results with?
I have a 2001 302 Windsor which got a new radiator & hoses around a year ago. There are no temperature issues but I would like to flush the cooling system before the Sydney summer.
au350hp is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2018, 08:35 PM   #2
GASWAGON
Default Re: Radiator coolant/water ratio?
Old rule is 1/3 Coolant to 2/3rds water.......OR 33% Coolant. (Concentrate not pre mixed!)
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2018, 08:43 PM   #3
happy1
Hi,
Wouldn't this depend very much on the quality of the coolant, and if it's a 'concentrate' or not?
I would get the best possible coolant at a reasonable price (some are marked with '5 year', some are marked with 350.000km guarantee), and I would follow strictly the mixing ratio described on the bottle.
Cheers,
happy1 is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2018, 08:54 PM   #4
GASWAGON
Nulon now make a very LOOOOONG lasting Coolant called.......... ONE.
Its in all Auto shops.
The idea is that it only ever gets filled/fitted ..........ONCE and supposed to last FOREVER!!!!!
I run Nulon Semi Synth 15W40 in my BFWGN too!!!
Will fit Nulon ONE next year i think???
Old 31-07-2018, 08:59 PM   #5
The higher the coolant antifreeze ratio... The less cooling efficiency you get.
The specific heat of antifreeze is less than that of water.
This means that for a given temperature change, the antifreeze will carry less heat each time it circulates from engine to radiator and back.
So a 50% / 50% ratio of coolant concentrate to water provides good corrosion protection but less cooling effectiveness.
A 33% ratio of coolant concentrate to 67% water, will give better cooling efficiency in Australian climate conditions and good corrosion protection.
Old 31-07-2018, 09:34 PM   #6
GasoLane
Former BTIKD
GasoLane's Avatar
One of the few Penrite coolants recommended for my (non Ford) car is the Penrite 7 Year 450,000KM Green Concentrate.
But says it should be used at a concentration level of 50%
Old 31-07-2018, 11:58 PM   #7
au350hp
Thanks for all the advice. I have used Penrite for everything else so may as well continue the trend with the Penrite green. Interesting comment on the 50% mix though and as GasOlane says, that's what Penrite recommend. Is their mixture somehow more effective at that ratio? I remember when I changed he radiator & hoses that X amount of water stays in their so do a flush after a few kays.
Old 01-08-2018, 12:54 PM   #8
MattSAU2XR8
I'd go by what it says on the packet, and also:
- Choose the longest lasting coolant available - I think for example Nulon make a ten year or 1 million km coolant now?
- Make sure the manufacturer says its suitable for your car
- Flush the radiator properly with tap and then distilled water
- Mix it with distilled water in the highest ratio of coolant to water recommended on the pack - unless you have overheating problems more corrosion protection would be better than less
- Change it out at about 2/3 of the interval recommended by the coolant manufacturer. Given a coolant change is only going to cost about $100 and a few hours of your time, if it saves you a single radiator, heater core, transmission heat exchanger, or welch plug its paid for itself many times over :-)
MattSAU2XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2018, 01:00 PM   #9
123Cat
And check for residual current of course ,
I have 0.15 volts in the ED I6 radiator water with the engine on and
with 2 small bottles of Natrad conditioner with tap water, changed every year
Modern cars look like they have no residual current , It must be the very good non conductive coolants these days ,??????
Fords are cool
123Cat is offline   Reply With Quote Multi-Quote with this Post
