30-08-2018, 11:05 PM | #1 | ||
When installing or replacing stuff like side skirts, rear skirts etc where you have to glue the top edge with sikaflex are you supposed to put all of the clips & scrivets on first then apply sikaflex or glue it first then put all of the clips on?
30-08-2018, 11:13 PM | #2 | ||
Youth worker
My understanding is that you don't Sikaflex these things, you use automotive double sided tape (if needed at all) and appropriate scrivets and screws.
What car are you working on?
2007 FPV F6 Typhoon BFII, Neo. Build Number 325 2011 SZ Territory Typhoon Thread: Mr Brooksy's BFII Typhoon Territory Thread: Mrs Brooksy's SZ Territory Resurrection Old Futura thread:
Brooksy's Ex Build |
01-09-2018, 04:33 AM | #3 | ||
Hi,
Usually you need to apply the polyurethane (sikaflex or similar) to the skirt / panel, without smudging it onto the paint surface, then fitting the skirt / panel onto its clips. You may need to park the car near a wall and use some wood plank pieces or similar to put pressure on the skirt /panel against the car, and leave it over night while the polyurethane is going hard. If you have applied too much and it squeezes out where it shouldn't be, it needs to be cleaned up quickly, for example with a rag with petrol on it. Polyurethane is a lot stronger than double-sided tape, but a lot messier. Side skirts on BF FPV is one example of parts glued with Polyurethane. If some of the original clips / fasteners are broken off, it is often a good idea to add some polyurethane to hold a panel or skirt in place. Cheers, |
01-09-2018, 09:18 AM | #4 | |||
Youth worker
B series XR and low models skirts are simply clipped on. No need for tape, and my Territory uses clips only as well. Never seen a modern Falcon with side skirts attached with Sikaflex from factory. But then again I haven't touched FG onwards or AUs. Also a tip of you are attaching FPV shirts or anything with a rear dog leg, attach from rear to front! This stops the common problem of the rear dog leg fouling on the rear door so long as you line that up first. It would be very helpful to know what FordFord2 is fitting and to what! As this discussion is starting to go in circles.
01-09-2018, 07:45 PM | #5 | ||
Fitting stock skirts to a bf ute, I would prefer to use the 3m tape but at the top of the skirt the part that touches the car body is about 2mm wide & it turns in so there is a triangular shape below it with single sided foam tape about 10mm beneath that and the side part has about a 15mm gap between the body which is where the sikaflex should go, the double sided tape would need to be about 20mm & triangluar shaped to work.
