Old 07-08-2017, 11:50 PM   #1
WildRacer
Cougar King
WildRacer's Avatar
Question Cougar - Interior and Exterior lights flicker when Idle
Hi everyone,
I am a fairly new owner of my 2000 Eibach Cougar. I have noticed a few flaws which have been fairly easily corrected.
But one thing which is really bugging me while driving at night when stationary at the lights, the outside lights begin to flicker or dim (as do the interior) when the car is sitting idle. But then goes away when the revs pick up.
I did a few searched on newcougar and found that the 99/00 model had a weak ground connection which wares out over time. Apparently I have to apply something called the big three mod, which strengthns the ground connection.
Has anyone actually attempted this to their Cougars? If so was the process straight forward enough that anyone could attempt to do it?
Link of procedure on NewCougar: http://www.newcougar.org/forums/how-...e-visited.html
Cheers.
WildRacer is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2017, 06:31 AM   #2
russellw
russellw's Avatar
Default Re: Cougar - Interior and Exterior lights flicker when Idle
It's simple enough. We got the upgraded positive on AU spec Cougars so you only need to do the earth upgrade to fix the dimming lights issue.
Russ
Old 11-08-2017, 10:45 AM   #3
thearrow
Just hope it is not the alternator.
Owning a Cougar is like owning a Super Model
Good to own but "High Maintenance"
2000 Model Eibach Cougar (Auto) - Now dead & buried
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2017, 02:08 PM   #4
WildRacer
Cougar King
WildRacer's Avatar
Russ
Thanks Russ, I'm hoping to do it soon.
I hope it's not the alternator, heard they are a pain to change.
Old 14-08-2017, 04:35 AM   #5
REDDYZ
REDDYZ's Avatar
No its definitely not the alternator. Even if it is, they are not hard to change as everyone thinks. I've changed regulator on mine and looked impossible initially but with a universal joint and long extensions, bolts can be undone from the top (behind the engine under the bonnet). Once you know how and have the right tools its easier than other cars.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2017, 01:33 PM   #6
thearrow
Changing the alternator is apparently quite easy although my mechanic did it, you take off the drivers side wheel and it is quite easy or so he said.
Old 28-03-2019, 09:58 PM   #7
WildRacer
Cougar King
WildRacer's Avatar
Thumbs up Re: Cougar - Interior and Exterior lights flicker when Idle
Russ
Apologies for the big bump but thought I'd update in case anyone was curious. Did the earth upgrade from the loom to the alternator a couple of weeks ago and can confirm that this fix does indeed work! Was a bit of a pain of a job as the loom has to come from the back bottom of the engine to the top to do the soldering, but well worth it. All flickering has stopped and also feels more responsive too! no longer looks like a Christmas tree at night lol.
Also got a dicky Alternator too, from a long drive, It went into limp mode on the way home, had to get her charged by the RAA. Was smelling a bit electrical and making a whining noise. Lucky it's only my cheap second Cougar!
00 Eibach Cougar
Mods:
Escape 3.0 V6
ST220 UIM and LIM
NPG Fuel Adapter
California Clutch Stage 2 Disk and PP
ST200 Flywheel
Torsen LSD
Updated Shift Forks
ToyoSport Exhaust Headers
Custom 2.5" Exhaust dual
BAT 21mm RSB
PRT Heavy Duty rear drop links
Energy Suspension Polybushes all around
Eibach Suspension
Eibach body kit
01 Gauges
01 Steering Wheel
Aluminium Sports Pedals
Sony Double Din HU
ST200 Airbox
ST200 TB
Direnza ST200 Aluminium Radiator
Goodridge Brake Hoses
