Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
#31 | ||
Yeah, my BA suffered terribly with (stock) brake fade coming down a mountain with 2 harleys on the back. Low gears all the way and pray hard. Bendix pads and cooling ducts fixed the fade but rotor consumption could be measured weekly.
FG with ABS has been fantastic on the stock pads and rotors, it's why I'm hesitant to change to DBA/Bendix etc. Just been across the Simpson in my brother's PK Ranger with big wheels/tyres, slipping clutch and no brakes, the FG's pedal feels brilliant by comparison. Might be cheaper to leave mine alone and drive the Ranger once a month.
Now with half a million km's + |
#32 | |||
Race Brakes Sydney
The problem is we can't compare your bike brakes a to your car brakes as they are so different. If you go bigger in bore size on the master cylinder for a firmer pedal you will need more pedal force to pull you up plus $$$$$$$. You can try different brake pads and fluid but i am sure it wont ever get as good in firmness as your bike sorry.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
#33 | ||
Hi all.
Im looking at replacement opinions for rotors on my fg gtp. I would like two piece all round with nice looking slotts as the car is headed to be street/show/ family car, But it seems off the shelf, its looking like Front end, dba t3 5000 series (2 piece) Rear end, to have matching t3 slots is the dba t3 4000 series (1 piece only avaliable) Any input in this big steep would be helpfull Its a must to keep existing brembo 6 and 4 pot setup
Current 2009 FG GTP Sold 2003 boss 260 xr8 daily driver 1991 eb1 xr8 once a year driver, factory cassette player |
#34 | ||
GT-P With An Ego
can't have two piece rears because of the hand brake is a drum style.
the DBA 5000/4000 is what I run on my GT-P. with some good pads, is a great upgrade from the factory setup. let Matt help you choose pads, the right pad for you will depend on your usage.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
#35 | ||
Hi Matt,
I drive a BF MKII Ute with 16" steelies, it's an XL and to my dismay has NO ABS!!! (in this day and age... I didn't even think to check!) Anyway, I can see that if I upgrade to the 328mm disc I'll need new rims and I'm on a budget. I'm in my 50's and I drive like a grandpa now, but I was disappointed when I fitted speed sleeders to the ute and did three crash stops and found the brakes starting to fade already. The stock brakes are pathetic... My question is, is it worth it (will I notice the difference) fitting stock sized slotted rotors and better pads, or am I better off sourcing a set of 17" or 18" rims and fitting the 328mm slotted rotors? AND Did the G6 have the bigger rotors, as I'm looking at a set of rims off a wrecked vehicle? thanks for your time. |
#36 | ||
HI Matt,
I drive a BF MKII Ute with 16" steelies, it's an XL and to my dismay has NO ABS!!! (in this day and age... I didn't even think to check!) Anyway, I can see that if I upgrade to the 328mm disc I'll need new rims and I'm on a budget. I'm in my 50's and I drive like a grandpa now, but I was disappointed when I fitted speed bleeders to the ute and did three crash stops and found the brakes starting to fade already. The stock brakes are pathetic... My question is, is it worth it (will I notice the difference) fitting stock sized slotted rotors and better pads, or am I better off sourcing a set of 17" or 18" rims and fitting the 328mm slotted rotors? and did the G6 have ther bigger rotors, or was it only the G6T that had them? thanks for your time. |
#37 | ||||
Race Brakes Sydney
The front upgrade is 322mm and takes the same pad as the 298mm kit but with the larger rotor and a good set of pad is a better option. All Turbo and V8 Fords in BF and FG have the 322mm set up. You could also try the DBA T2 rotors and the dba XP all round as we have found that a good improvement on the RTV cars. Quote:
MATTHEW PEARCE
#38 | ||
thanks for the reply. I'm going to leave the rear rotors stock and I was after stock sized, better (read adequate) performing rotors and pads so they fit my stock wheels...
#39 | |||
Race Brakes Sydney
You can get the top of the line DBA T3 slotted rotors and there DBA SP street brake pads for about $470 delivered Australia wide.
MATTHEW PEARCE
#40 | |||
Email sent to race brakes. In regards to rear two piece. Waiting for reply. Rodger, Over
#41 | ||
Race Brakes Sydney
haven't seen it
MATTHEW PEARCE
#42 | ||
#43 | ||
On the search for cubes..
Morning, afternoon or evening...
Just wondering if you sell the E series brake upgrade kits still and what would be the cost on these please and thank you?
FG G6ET - Daily Driveway Ornament... Current Projects ED SOHC 3v 5.4 Cammed 5.4 3V Garage Ornament Project Project Brimstone XE Wagon Phase 6 powered by Coyote Long Gone Projects EA Falcon SOHC 4.0 237rwhp BA 3V 'The Taxi' DJR320 Kit, G6ET Wheels, Lunati Voodoo Cams 320rwhp |
#44 | ||
Race Brakes Sydney
$2450 for the front kit complete with exchange uprights. Twin piston 330m slotted kit
MATTHEW PEARCE
#45 | ||
Hi Matt.
Just wanted to get pricing and availability on FG rear 303mm solid rotors and pads. Not sure if I could be bothered with slotted though on them ... and the factory items actually managed to make it to 220,000km with no issues. And if you have them anything in stock to pick as as soon as i can .... please. As a side note. Had no notification it was going to do this until it started grinding on the way to work this morning ![]() As I mentioned though .... 220,000km from OE is pretty decent in my book. (my fault though .... has been a while since i checked them) Thanks in advance
#46 | |||
Race Brakes Sydney
Bugger and i can have plain rotors here today if you want them. Just ring me 02 96091101
MATTHEW PEARCE
#47 | ||
Thanks Matt .... I'll call you soon
#48 | ||
Hi Matt, how much for braided brake lines and new pads all round for a 4/pdr brembo set up on a FG GS sedan
#49 | ||
Race Brakes Sydney
Is that a Brembo/PBR set up ? $288 delivered thanks
MATTHEW PEARCE
#50 | ||
#51 | |||
Race Brakes Sydney
Brake pads would be an extra $260 to $360 depends on brand but the cheaper option quoted is the DBA SP STREET Pads and the dearer is the new Project Mu NS-EP brake pads.
MATTHEW PEARCE
#52 | |||
![]() I'll go with the DBA pads and brake lines, I'll send you a PM |
#53 | ||
hi i need a price for brake pads for 4pot brembo fronts and standard back for bf f6 typhoon
BF F6 Typhoon: Fully opt. Standard except for filter and turbo line |
#54 | ||
Race Brakes Sydney
Prices range from $120 to $220 each set but most popular are the Project Mu pads still and would cost about $350 for both sets. These are less dust as well.
MATTHEW PEARCE
#55 | ||
Hi Matt,
hoping that you may be able to help me with some information on some rotors that i have in my shed. they are the same with the exception of the rotor thickness part numbers as below with the only difference being the AA and AB. i believe the AA are AU falcon but not sure on the AB set being thinner. brake rotor part # 84222C026 AA brake rotor part # 84222C026 AB Cheers Shane
AU XR8 series II N/A 6 speed manual 426HP 730Nm 1/4 mile: 12.44 sec @ 110.42 MPH Build thread http://www.fordforums.com.au/showthread.php?t=11410574 |
#56 | |||
Race Brakes Sydney
MATTHEW PEARCE
#57 | ||
Hi Matt, I am in need of 2 x DBA 42108S discs and a set of ceramic low/no dust pads for the rear of my Territory (Modified 6/4 Brembos).
Can you PM me a price please mate? Wangara. W.A 6065 Cheers
2015 FGX XR8 5.0 S/C 645 RWKW ![]() |
#58 | |||
![]() ![]() Thanks Matt. i forgot to mention that they are rear rotors both with elliptical grooves and the thin one is only 10mm thick.
#59 | |||
Race Brakes Sydney
AU REAR Series 1 DBA501 287MM X 10.5MM Eliptical slot disc sounds like could be rear BA which is 303mm x 16mm DBA505
MATTHEW PEARCE
#60 | ||
![]() Join Date: Oct 2006
So what's Race Brakes view on the issue discussed in this thread https://fordforums.com.au/showthread.php?t=11489913 ? i.e. should brake caliper and slide pin bolts be reused?
regards Blue |
