Gday - I have a 2004 BA falcon - 120,000 on the clock. Runs well but I'm think the timing might be out or maybe it just needs a EFI cleaner. I'm used the old school fords which is why I ask (timing light, adjust distributor). The engine feels as though its timing is out - its running between 500 to 700 on idle while in drive (auto obviously) and cant make up its mind between the 2 - its making the car rock side to side which used to be awesome in my old v8's but is really annoying as its not steady if you know what i mean. Its been getting progressively worse. I did a home service about a year ago - just sparkies, air filter, oil etc but no pros. ie no computer hookup. So do I need that or just EFI cleaner and if so would you recommend the spray into the air filter or the petrol tank one.
Cheers Sam |
Very hard to diagnose from here, but could be a vacuum leak in the intake manifold, with the engine running spray some aero start along the intake manifold where it meets the head. See if the revs pick up and that might be your problem. Only an educated guess but worth a try.
3 users like this post: |
#3 | ||||
![]() Join Date: Oct 2006
As I have said numerous times on this forum (e.g. https://fordforums.com.au/showthread...ght=smoke+test) : Quote:
regards Blue |
