As per topic, for those of you with emergency window breakers and seatbelt cutters, where abouts in the car are you storing them?
I obviously want it within reach of the driver's seat but not sure where the best spot is. To date I've had it in a compartment beside the steering wheel but I don't think that's a great idea, the latch is getting loose and I'm pretty confident it'll pop open in the event of a rollover and the tool will disappear somewhere out of reach. Silly me threw out the plastic holder it came in so mounting it is probably no longer an option. Sooo.... where's yours? Pics appreciated if you have them. |
In the glove box
![]() Join Date: Nov 2006
That's the other use for headrests, breaking windows.
The Stable. AU II XR8 Daily driver. BF XR8 ute (Red the only true Modification) ![]() The boy, XT Ute 393 cleveland. Genuine XB GT. |
Only because i needed to replace and mount the fire extinguisher for my boat, and i know its different. I put one in my car too. Its mounted to the passengers side of the trans tunnel so easy reach and doesnt impede the driver.
Yes it does look a little bit out of place, but it only slightly impedes the passengers side. That doesnt concern myself as im the driver and it doesnt impede me. It is a fire extinguisher not a window smasher so it does take up a tad bit more real estate. I'll put a pic in an email.
Experienced Member
Most doors have pockets which you can screw a clip to bottom then use a small thin cable tie to attach which can be easily broken to access these utilities. Hopefully should be in easy reach in any event.
#9 | |||
Sent from my SM-G950F using Tapatalk |
#10 | ||||
![]() Join Date: Oct 2006
regards Blue |
i thought centre console , you don,t have a console?
while on the safety issue , get a 1kg fire extinguisher, after i attended a car accident, a trapped female and car was on fire, and nobody had a fire extinguisher. |
