Old 12-04-2021, 03:06 PM   #1
sang54
sang54's Avatar
Default Ba xr8 fpv
Hi all, I’m hoping someone may be able to shed some light on this. I am looking at purchasing a BA XR8 and it has a FPV tag under the bonnet (photo attached) which states it has a FPV test engine in it and that it is 1 of 10 built. It also has a FPV dash cluster and and FPV vin number tag on the radiator support. This car is definitely not a GT as it is the 260 motor. Any more info on this car would be great, cheers.
File Type: jpeg ED7ED082-E601-4856-AD1D-B153FBE5067B.jpeg (36.8 KB, 188 views)
sang54 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2021, 03:29 PM   #2
Bossxr8
Peter Car
Bossxr8's Avatar
Default Re: Ba xr8 fpv
Possibly a pre-production test car. Motors were built by FPV.
Unusual because i've never seen metal tags fitted to test cars like that.
When was the car built?
Old 13-04-2021, 12:26 PM   #3
bangm001
Mopar! But Own F6's..
Doesnt look right to me.
F6 TYPHOON
FPV 335 GT
bangm001 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2021, 12:39 PM   #4
GT450
FPV assembled all the 5.4 litre engines , the 290s were balanced and blueprinted and used several different parts to it's 260 counterparts. If the tag matches the engine number on the block I can't see what the problem is. It does not make the car and official Ford Performance Vehicle however.
GT450 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2021, 12:51 PM   #5
Polyal
The 'Stihl' Man
Polyal's Avatar
Agreed, I call BS and by now something would have popped up here.
Get them to prove that 10 engine program existed. And even if it did then those 10 engines would most likely not make it to the customer...lastly, id rather not have a test engine even if it was legit.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Polyal is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2021, 01:28 PM   #6
Bossxr8
Peter Car
Bossxr8's Avatar
I've simply never seen a test vehicle with any form of tag advertising that it is a test vehicle, let alone one that has the number of them built on it. Very odd.
That's why I asked when it was built, as if it was built before roughly Oct/Nov 2002 then it could be a pre-production model.
Old 13-04-2021, 02:04 PM   #7
Smoke Pursuit
That aint legit....
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Old 13-04-2021, 02:40 PM   #8
sang54
sang54's Avatar
Hopefully the seller gets back to me today with the build date. Thanks for your replies so far.
Old 13-04-2021, 05:16 PM   #9
Do you have the VIN number, as that will decode the build date for you.
DFB FGXR6 is online now   Reply With Quote Multi-Quote with this Post
Old 13-04-2021, 11:24 PM   #10
Sprint XR8
Sprint XR8's Avatar
https://www.gumtree.com.au/s-ad/karr...pytopasteboard
2003 build so it won’t be pre production.
Sprint XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2021, 04:33 AM   #11
Interesting, thank you for the link. Hopefully the VIN can be diligently probed.
In case the ad goes, FPVH3J06923 / 6FPAAAJGSW3J32438
Old 14-04-2021, 09:06 AM   #12
Bossxr8
Peter Car
Bossxr8's Avatar
It's a 2003, so how the hell can it be the first ever made when they went on sale in 2002?
Seller is an idiot.
Old 14-04-2021, 09:35 AM   #13
raised by monkeys
raised by monkeys's Avatar
Seller is an idiot.
This was my thought and first giveaway
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
Old 14-04-2021, 09:43 AM   #14
What does the VIN decode as?
Old 14-04-2021, 05:08 PM   #15
Seller is an idiot.
XR8 and GT with the Boss engines launched in early 2003, Febuary for XR8 and March for FPV models.
Old 14-04-2021, 08:04 PM   #16
Smoke Pursuit
That was autos.
You could buy xr8 manuals from the start...
Old 14-04-2021, 08:30 PM   #17
Originally Posted by Smoke Pursuit View Post
That was autos.
No, auto Boss 260/290 arrived in April (Q2) 2003. Manuals launched as above.
Check the fine print in this brochure scan, "260kw XR8 engine available early 2003"
http://www.fordforums.com.au/photos/...php?photo=4959
BA XR8 and FPV model were however announced late 2002.
Old 14-04-2021, 08:30 PM   #18
Mont5.0
Mont5.0's Avatar
where can i buy one of those plates???
Ill stick it in my engine bay but make it 1 of 500, just to keep it real.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 14-04-2021, 10:52 PM   #19
V8Crazy
V8Crazy's Avatar
Only time i've seen a genuine test vehicle was a BA XR6T test car, it had a basic interior (Like bottom like everything, no carpets, no trims, a dash but no glove box/etc, plus lots and lots of holes drilled everywhere where they obviously had things mounted).
It also had a VIN that was basically the ford code and then all 1's.
The car couldn't be registered because the vin was an invalid VIN and the car wasn't ADR compliant. As such the car was being used as a track car at the time.
Even the ECU was a pre-production ecu that was so wonky and locked down that it couldn't be accessed tuned (by sct xcal at the time). After much mucking about, they ended up getting a ECU and engine harness (as the harness with the test-bed ECU was very different to production) so they could tune it.
From memory that introduced a myrid of other bugs in the car (due to pre/post production mixing) but nothing that really effected it in the sense of tracking the car.
It didn't have any special plates, just had all standard ford stickers and such and the VIN was invalid.
Driving : 2006 BF XR8 6 Speed Manual in Toxic Green
Power : 320rwkw - 710nm of Torque - Retune Incoming (Aiming for 380rwkw)
Tuned by: Ben Hill @ Hills Performance - Narellan, Western Sydney
Mods : Capa Vortech V2 SQ Supercharger @ 8psi w/ Griptec pulley, 42lb injectors + 2Bar Map, W2A intercooler, Walbro GSS342 Fuel pump, Raceworks Adjustable Fuel Reg, 2.5" XForce Quadtip Catback Exhaust, 100 Cell Cats, Xforce Stainles Extractors, 25% underdrives
V8Crazy is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2021, 02:52 PM   #20
Bossxr8
Peter Car
Bossxr8's Avatar
Nope. Manuals were available late in 2002. The autos didn't arrive till Feb. I know cause I had ones of the first autos delivered, and I had a manual XR8 to test drive in december. So they 100% were building and delivering manual xr8's in 2002. Although the xr8's came on line later than the 6 cylinders did.
They usually start delivering cars to dealers before the actual published release date, that way it gives them some time up their sleeve if they have any issues.
Old 15-04-2021, 04:16 PM   #21
tweeked
N/A all the way
tweeked's Avatar
Also, it is a “Ford Performance Vehicle” the company always labeled with an S
BA GT
5.88 litres of Modular Boss Powered Muscle
300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight
tweeked is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2021, 06:03 PM   #22
genebaby
Abuser of Charvels
genebaby's Avatar
I met a guy a long time ago that had a 2002 build XR8. I think it was November. I can't remember if he had an auto or a manual.
Contraband Facebook
Daily: Tornado MY20 GTI
Retired: Venom BA XR8 - build thread
genebaby is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2021, 07:03 PM   #23
Interesting, I might have to revise my records then.
I remember the media launch drive for the XR8 being after the rest of the range. It was also absent from the Wheels Car Of the Year testing that year.
Jan 2003 review-
https://www.goauto.com.au/new-models...1-27/3039.html
This also from GoAuto at the time -
"The BA Falcon, however, will not go on sale until October, when mainstream Falcon sedan, ute, wagon and XR6 models are likely to be offered at a premium of three to four per cent over current AU models. But the BA XR8 will not appear until early 2003..."
https://www.goauto.com.au/new-models...9-04/3041.html
"The XR6 Turbo slots into the XR6 range above the Barra 182-engined XR6 and below the yet to be released XR8, which we know gets a 260kW four-valve version of the new 5.4-litre modular V8 called the Boss."
https://www.goauto.com.au/new-models...9-27/3040.html
Also, as I linked, the BA Falcon brochure states the XR8 would be available early 2003.
So having said all that, and from what others have said, I'm guessing Ford started to manufacture XR8's from late 2002 to build up stocks for 2003 delivery? I'm also guessing this allowed FPV to build up a stock of engines.
Old 15-04-2021, 10:41 PM   #24
GTLEGEND
9/2003 BA XR8 5.4 4 Speed Auto White Police Pack
Old 16-04-2021, 09:29 AM   #25
au2000
AKA "the other bloke"
au2000's Avatar
Pretty sure this is the XR that’s being referred to.
https://www.carsales.com.au/cars/det...-7064845/?Cr=2
Looks dodgy as to me
Given the condition of the paint outside compared to door jams etc, and it’s unregistered I’d not be surprised if it’s a stat write off re bodied etc, especially after gtlegend’s info..
Her's: 2000 AU II Fairmont Ghia 75th anniversary VCT meteorite & 2014 yaris - white
His Toy: 2012 fg II GT-E, emperor red
His: VS Ute 5 Litre 5 speed (povo pack)
His: 2012 FG II GS, Vanish
His: 2003 BA GT-P, Lightening Strike
Jnr: 2002 AU III Falcon XR6 ST, 5 speed Blueprint & 1978 XC Fairmont Neptune Blue
Previous:
1976 HX 50th Anniversary Kingswood
2014 FGX G6E Turbo
1980 XD Falcon GL
2003 BA Falcon XR6
1991 EB Falcon S
1989 EA Fairmont
1982 XE Fairmont
1968 XT Falcon
au2000 is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2021, 10:23 AM   #26
Smoke Pursuit
Jan 2003 review-
Could definitely get BA XR8 manuals in late 2002, autos came later.
Old 16-04-2021, 10:26 AM   #27
Polyal
The 'Stihl' Man
Polyal's Avatar
Hard pass
Old 16-04-2021, 12:02 PM   #28
Bossxr8
Peter Car
Bossxr8's Avatar
This looks sus af. Why would the tyre placard only have a 16 inch tyre listed, when XR's only came with 17's and 18's? And why would an XR have datadots? Only FPV's got those. Reckon someone has added a bunch of things off a GT wreck and is trying to pass it off as some some of FPV prototype.
So many things just don't add up.
Old 02-01-2023, 09:50 AM   #29
cossie88
cossie88's Avatar
Did you ever find out what the test engine means?
I have a BF GT that has a test engine tag on a decal in the valley of the 5.4 and am trying to find out what it means. My car is an ex BP Australia owned which was one of two ordered by BP Australia for testing of their newly developed BP ultimate fuel. The other BP car had Manley rods fitted to it but the current owner didn’t fit them and he doesn’t think engine was upgraded by previous owner as he bought it stock original from him.
cossie88 is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2023, 10:35 PM   #30
sang54
sang54's Avatar
Hey mate, sorry I had no luck getting to the bottom of this so I did not buy the car. The engine in my current XR has Manley rods in it but they where added during the engine rebuild. Sorry I can’t be much more of a help. I’m sure your running into the same brick walls I did on google as there is very little info on these test engines. Good luck, cheers.
BA XR8 Ute S/C
394 RWK with more soon to come.
