09-03-2023, 12:05 PM | #1 | ||
Hi all < New to the forum , i have recently bought a 2000 NU fairlane Ghia V8 , PO had cut holes in the bonnet , i want to replace it with a bonnet with the Bulge . Can this be done without too much work or better still , straight swap . Thanks Mark
19-03-2023, 02:21 PM | #2 | ||
Next upgraded Mk1 Leopard
do you mean this ?
https://www.ssv.com.au/bulge-bonnet-...airmont-falcon
19-03-2023, 10:10 PM | #3 | ||
Hi . Yes thats what had in mind ? Would that be a direct bolt on or any mods needed .thanks mark
20-03-2023, 09:19 AM | #4 | ||
I would say probably no, HOWEVER I would call the guys on that website to confirm you can. (Edited for future questions.)
25-03-2023, 10:09 AM | #6 | ||
How did you get on?
02-04-2023, 12:08 AM | #8 | ||
#neuteredlyfe
I think that what you are essentially asking is if the Falcon bonnet will fit a Fairlane? If so, then no the Falcon bonnet will not a Fairlane.
If you are asking if the bulge itself will bolt on easily then sorry, the answer to this is also no. I am sure that you could do it, but it would not be as easy as bolting it straight on. |
02-04-2023, 10:55 AM | #9 | ||
Thanks for the message , will do more research
02-04-2023, 11:13 AM | #10 | ||
Former BTIKD
02-04-2023, 11:39 AM | #11 | ||
looks like a no fit to me, Thanks mate.
