AU-XR8-302
Does anyone know if the standard Falcon/Fairmont Perspects instrument cover is the same as the Tickford plastic covers???
My cluster is fine, but all the plastic clips on the perspects are broken. Its cheap to buy a standard cluster and replace the plastic cover if they are interchangable? Tony. Last edited by avisionit; 25-05-2023 at 11:09 AM. |
#neuteredlyfe
![]() ![]() Join Date: Apr 2012
The perspex cover will fit in terms of fitting over the cluster itself.
The problem you run into will be the odometer reset button is positioned differently. |
AU-XR8-302
![]() Join Date: Jun 2007
Fairmont Ghia and Fairlane Ghia plastic cover will fit tickford cluster. Anything else won't as per what PG2 said.
#5 | |||
AU-XR8-302
Thank you. |
