Old 28-07-2024, 09:47 AM   #1
Default Diesel: Have I Lost a Check Ball?
Approaching reassembly, got a question for the CR diesel experts.
During tear down I assumed the subject banjo fitting had a stepped head and just ratcheted away without really looking. Next thing I had a stop bolt, copper washer and a fine spring about 20mm long in my hand. It came off the end of the actual banjo bolt. Clearly, I wasn’t 100% focused that day.
What I’m wondering is, in this process of misadventure did I lose a check ball or some type of poppet valve? I did not observe anything falling, or see any piece on the ground when I immediately stopped to look.
PLEASE NOTE: POSTIMAGES MAY NOW CARRY PORN ADVERTS ABOVE AND BELOW ENLARGED IMAGES
Old 30-07-2024, 04:46 PM   #2
tbro4123
Default Re: Diesel: Have I Lost a Check Ball?
Been a while since I worked on that style Denso pump but from memory that fitting is a bleed off valve and is sealed from the factory so if the spring is broken or its not holding fuel pressure then its replacement time.
Sorry can't help more but my memory is getting very vague these days.
Terry aka Tbro
ps them piccys is naughty!!!!!
tbro4123 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2024, 04:56 PM   #3
Thanks - it looks reasonably generic but I hope to work out if it’s lost a check ball or has a flat poppet style valve. Can probably remove the whole bolt and examine carefully. Felt like a right idjit when I did that.
Old 30-07-2024, 05:08 PM   #4
Franco Cozzo
Franco Cozzo's Avatar
Originally Posted by Citroënbender View Post
PLEASE NOTE: POSTIMAGES MAY NOW CARRY PORN ADVERTS ABOVE AND BELOW ENLARGED IMAGES]
Mine only has tax stuff :(
Old 30-07-2024, 05:29 PM   #5
Have we accidentally swapped phones?
Old 30-07-2024, 06:15 PM   #6
mad2
Regular...with metamusal
DAMN!
i who have nothing ...... feel sooo.oo left out
Old 30-07-2024, 07:50 PM   #7
I know you are a Francophile CB but are hinting you have gone to the extreme extent of now trying to emulate Napoleon Bonaparte and join Yhis list of celebs: https://www.ebaumsworld.com/pictures...icle/82747480/ "10 Celebs With One Testicle "
Old 02-08-2024, 02:30 PM   #8
Had a chance finally, to investigate deeper. Check ball was not lost, everything is OK.
Old 02-08-2024, 03:24 PM   #9
DAMN!
So have you lost both yours?
Old 02-08-2024, 04:14 PM   #10
mad2
cats like to play with em.............
