Old 02-10-2024, 02:48 PM   #1
Fatbob103
Default Waterless Carwash Options.
Gunna get some hate here for multiple reasons but looking for some advice on good waterless carwash options.
Basically my Harley sits around a lot lately not being used and with living in units , giving it a quick wash isn't an easy thing to do.
I'd like to be able to pop out to the garage once a week and give it a once over to keep it looking half decent without having the hassles a full on proper wash is going to cause me at the moment.
Anyone got any recommendations?
Fatbob103 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2024, 08:14 PM   #2
prydey
Rob
prydey's Avatar
Default Re: Waterless Carwash Options.
https://fordforums.com.au/showthread.php?t=11498268
UA2 TREND 4WD BI TURBO
prydey is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2024, 08:55 PM   #3
Captain Stubing
Looking for clues...
Captain Stubing's Avatar
I had a Fatbob for about 12 years, I sold it because I thought I had to compensate for buying a project car. I regret doing that most days now, as the Minister for Finance told me I didn't have to.
I found a mob selling stuff in supermarket carparks worked well, spray on, wipe off with a clean shine.
https://www.fw1.com.au I think it was.
Prydey's link is a good reference though.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute
1985 XR4Ti Sierra - Build Thread
1971 Fairlane 500
and... a collection of Jeep Towpigs
and... two collections of rust and some new plastic bits roughly shaped like an F-Truck
and.... some spare metal bits with holes in them
Captain Stubing is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2024, 07:40 PM   #4
Originally Posted by prydey
Ok, so that posted link is quite in depth, so I'll shorten it down into an easily digestible format.
Firstly though, "rinse-less" and "waterless" washing are two separate wash methods.
Waterless washing involves no water, just a sprayable product and a bunch of towels. This the least safe of all washing methods, but can be done in a pinch with correct product choice and technique.
Rinse-less washing does in fact use water, and depending on method, you wash the car in a similar way as a traditional bucket/soap wash. The difference being the washing solution is not rinsed from the vehicle at the end. Important to note that this method involves rinsing less, you can still pre-rinse the vehicle beforehand if desired. And this is where most people get hung up when it comes to rinse-less washing.
For you, I would be looking into the "Garry Dean" rinse-less wash method. This will be a quick, convenient and SAFE method of washing. If you are new to this, check out the video below.
In that case, he is using McKee's N-914, but any rinse-less would be fine. For a newbie, I would recommend Optimum No Rinse (ONR), it's basically foolproof. Just make sure to get the latest revision 5. If you want to go nuts, then check out Gyeon EcoWash or P&S Absolute. If you want something readily available, check out Bowden's Dry Spell.
https://detailingshed.com.au/product...967753f3&_ss=r
https://detailingshed.com.au/product...45126376358103
https://detailingshed.com.au/product...e&_ss=e&_v=1.0
https://www.supercheapauto.com.au/p/...E&gclsrc=aw.ds
Feel free to ask questions, it can be a bit weird when starting out with rinse-less, but it makes a lot sense for this sort of situation.
