Old 14-07-2006, 03:25 AM   #1
ThoR_
Holdens Fall Apart!
ThoR_'s Avatar
Lightbulb A Q On Escorts
hey guys i keep seeing targa videos and tarmac rallys and these MK1 and 2 escorts and ever time they do a U Turn these things snakey up the road? How the heck are these guys getting this power out of these things? Are they highly worked or just a little bit?
im really interested in them
Thanks!
AU2 XR8, Venom Red, 200kw, K&N Panel Filter, 2.5" Lukey Exhaust
ThoR_ is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 11:02 AM   #2
fpv_escort
They are all mostly twin cams and Bda escorts. They cost a fortune though but you could get a twin cam for maybe 20,000 and then you wouldnt really have to do much with the engine because they are already quite pokey.
fpv_escort is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 12:48 PM   #3
sean.ben
i think that you will also find that the setup in the rear has alot to do with it as well, apparently by fitting a four link rear with a watts link it takes all the play and give out of the rear end there fore making it quite stiff....................apparently!
sean.ben is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 04:09 PM   #4
ThoR_
Holdens Fall Apart!
ThoR_'s Avatar
i thought it would just be carby, cam, exhaust, extractors, lsd
Old 14-07-2006, 04:16 PM   #5
sean.ben
only if it was that simple, i would be peeling up the road right now
Old 14-07-2006, 10:22 PM   #6
RS027
Perth XR5'er
RS027's Avatar
Power from a BD series engine and a good LSD is the reason.
Ford Rallye Sport Club of WA; Member#64:
Barbagallo Short: 1:01.1779
Barbagallo Long: 1:12.4649
Collie: 55.90
K&N Gen2 57i CAI / 2XS RIP / Airtec Gen3 IC / Mongoose Dump Pipe / Outlaw 200cpsi Cat / Milltek Ultimate Race Catback / Whiteline 24mm RARB / Whiteline FALK / BC Racing BR-Spec Coilovers / RSR Rear Camber Arms / Ferodo DS2500 Pads F&R / Goodridge Braided Brake Lines / Elevate Torque Mount / DS MOD C / MkII RS Clutch & DMF / Quaife LSD
RS027 is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 03:51 AM   #7
ThoR_
Holdens Fall Apart!
ThoR_'s Avatar
so i cant get this sort of power out of say an RS2000? or a 2litre escort?
Old 15-07-2006, 03:29 PM   #8
fpv_escort
yeah you could but you would be up for a lot of money, it would be your choice
Old 15-07-2006, 04:36 PM   #9
RS027
Perth XR5'er
RS027's Avatar
I'm picking my RS2000 up today after 8 months getting the engine and gearbox rebuild. After over $11000 it should produce 160hp at the fly which is around 60hp over standard. The BDA's the classic rally guys are using produce close to 250hp at the fly and cost anywhere up to $50000 for a full competition engine. The other option is going Cosworth YB, cheaper than the Cosworth BD series engines, but still expensive if things go wrong. The Pinto if built right should be bulletproof to spin to 7500revs with 160hp on tap so you can run it every day, where the other engines would be play things only. AT only 1000kg's a 160 hp Pinto Escort will be a flyer, just never a real tyre fryer.
Collie: 55.90
Old 15-07-2006, 10:10 PM   #10
V8falcons
V8falcons's Avatar
A pinto engine can push 220hp N/a if built and tuned correctly.No a very good daily driver at all but still pushes the ponies.
my turbo EFI 2ltr pinto Im hoping for 300hp fly eventually after some development and money, long term.
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2006, 01:14 AM   #11
RS027
Perth XR5'er
RS027's Avatar
Wink
FF&R in the 90's released an artilcle about the "magic" 100 hp per Litre mark in the pinto. Many people claimed it was possible, but nothing had been proved. They tried everything and couldn't get more than approx 190hp.
Even with the advance in EFI the pinto parts catalog has remained relatively standard and only small increases have been seen. If you can get 220hp out of a Pinto on an engine dyno, not a chassis dyno, I know alot of people who'll be banging down your door.
This is the article
http://classicford.mine.nu/forum/top...?TOPIC_ID=5144
As for a turbo pinto. 300hp easy. Just add super strong internals and crank up the boost. Skies the limit until it shoots a rod out the block.
Collie: 55.90
