02-09-2006, 11:08 AM | #181 | ||
Also after the following items, part numbers and costings if you have them please
Chrome Door Handles - Inside (To fit AU Series 1) (Each or pair or set of 4) Chrome Button for Auto T-Bar (To fit AU Series 1) Chrome Button for Handbrake (To fit AU Series 1) Thanks again
:eclipsee_ MY CAR :eclipsee_
02-09-2006, 12:07 PM | #182 | |||
AU2 16360 A KIT - MUDFLAP - REAR, LESS BODY STYLING KIT, 4 DR SED $33.80 AU2 16360 KT KIT - MUDFLAP - REAR, WITH SIDE SKIRTS, LESS XR BODY KIT, 4 DR SED, (-)XR $31.30 ER 16268 A KIT - MUDFLAP, LESS BODY STYLING KIT, FRONT $31.10 AU3 16268 KTA KIT - MUDFLAP, WITH SIDE SKIRTS, LESS XR BODY KIT, FRONT, 4 DR SED, (-)XR $33.80 These are kits and come complete with all mounting hardware. Cheers Russ
02-09-2006, 12:11 PM | #183 | |||
Cheers Russ
02-09-2006, 01:04 PM | #184 | |||
02-09-2006, 09:25 PM | #186 | |||
Cheers Russ
03-09-2006, 12:26 AM | #187 | |||
In the below pic is both the t-bar shifter and the handbrake lever, both with the silver button, (Yes i have circled these to make sure i am explaining myself correctly) and i need them in the same colour as the interior of my car The link you gave me shows the handbrake as: AU Leather Handbrake: ER 2760 B6 about $200 plus the boot. But i dont know if this is the right one, and in the right colour... also i could nto find the correct t-bar with chrome button thanks again
03-09-2006, 08:50 AM | #188 | ||
I had DL LTD once and had to replace the leather T-bar auto handle. Cost me $300!! They nfitted slightly the wrong colour, so I made them change it.
Some people think I suffer from A.D.D., but they... Oh LOOK! A Chicken! |
03-09-2006, 09:31 AM | #189 | |||
07-09-2006, 12:44 AM | #191 | |||
If you want the individual bits then use the Parts Database Search Tool and search under mirror. Cheers Russ
12-09-2006, 06:59 PM | #192 | ||
Hi russellw !
I have AU 1999 xr6 vct 5sp I was told today i need new clutch and asked how much was told $1400 fitted. My reaction was am geting new car for that price. My question the f3zz7563a is that the right one i assume it is ford part number and price? Is there an aftermarket kit that could be used ? cheers |
12-09-2006, 07:26 PM | #193 | ||
I would have thought the relevant bits were these ones:
EDTVE 7563 A PLATE CLUTCH PRESS, (4.0L SOHC EFI 6 CYL (VCT) 5 SPEED MANUAL (T5) OR 4.0L SOHC EFI 6 CYL (HP) 5 SPEED MANUAL (T5)) 537.00 Not sure which actual clutch plate. The F3ZZ unit is also a pressure plate plate but I suspect it's a V8 one.
12-09-2006, 07:45 PM | #194 | ||
Thanks for your reply. Look i realy have no idea as F3ZZ was the most expensive i thought it could be it. And to confirm these are ford part numbers and prices is it gst inclusive?
Thanks for your help. |
12-09-2006, 07:56 PM | #195 | ||
These are Ford part numbers - prices were correct last December when we created the DB but they won'tr be now inevitably.
Cheers Russ
13-09-2006, 02:20 AM | #196 | |||
It should be that grey colour ... I have the handbrake and boot with chrome button sitting at home ready to swap in ... only problem is .... I need to pull the driver's seat out to swap it over (it's the only way to do it too). handbrake and boot was over $200 from memory ... as the handbrake is the entire ratchet mechanism as well with cable to mount under the floor of the car.
13-09-2006, 02:44 PM | #197 | ||
russellw thanks it is much appreciated. Yes the prices must heve gone up as the $ 1400 was ford service workshop price. I asked the guy how much if i supply the clutch he sad just labor and machining of the fly wheel $ 580 so that leaves $ 820 for clutch.
Thanks |
22-11-2006, 12:33 AM | #198 | ||
I am after the rear boot badge that is located in the centre of the rear boot lid for a LTD AUII
22-11-2006, 12:59 AM | #199 | |||
The BA one is BL F42528 A NAME PLATE, LTD, LTD Cheers Russ
25-12-2006, 01:28 PM | #200 | ||
Oh Yeah!
hay russel you wouldn't happen to know how much a headlight switch would be? Just the standard black one in the forte... mine is broken :( thanks
Oh no! Duffman can't breath! Oh, yeah! |
27-12-2006, 01:46 PM | #201 | ||
All of about $11 or so.
AU 11666 A Cheers Russ
24-01-2007, 11:23 PM | #202 | ||
Oh Yeah!
Thanks Russell. For anyone interested the head light switch (all of it) that plugs into the loom costs $48 from ford.
14-03-2007, 10:11 PM | #203 | ||
drive it like u stole it
hey, just wondering does anyone happen to no if the fuel tank sender unit in
the sedan is the same in the utes. |
15-03-2007, 10:49 AM | #204 | ||
The Ancient Warrior
Mate, I've checked everywhere and everywhich way but I can't find any info on an AU Falcon Drive Belt/Serpentine Belt e.g. part No. or price. What am I doing wrong or isn't it listed?
Chippy.. |
16-03-2007, 11:31 PM | #205 | |||
Cheers Russ
17-03-2007, 11:07 AM | #206 | |||
The Ancient Warrior
Thanks for that Russ. Chippy.. |
05-04-2007, 02:20 PM | #207 | ||
Hey guys...
using the parts database, it failed for me, i was just wondering if you's could tell me what this AU Falcon part number is from : WR2T-12A650-HB Cheers - Grechie
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
09-04-2007, 07:30 PM | #208 | |||
Cheers Russ
07-06-2007, 07:40 PM | #209 | ||
hi can u tell me what series au this ecu is from wr2a-12a650-cd
cheers |
07-06-2007, 10:51 PM | #210 | ||
The prefix is incorrect but the 12A650 CD is from a 5 litre 200 kW T-Series with 4 speed auto so therefore it is a T1, TE50.
Cheers Russ
