14-05-2007, 10:17 PM | #1 | ||
Formerly FTE666
Hey guys, got a '73 TC Cortina with the 2L motor, are the 200ci and 250ci I6's straight bolt in's? Or do you need to move mounts and everything else?
His - 1995 Ford Mustang Coupe, 3.8L V6, Auto, 2.5'' Dynomax dual exhaust, BBK underdrive pulley kit, Centric slotted and drilled rotors. Silver Hers - 2002 Ford Explorer XLT, 4.0L V6, 5-speed man, Blue, all options |
14-05-2007, 10:20 PM | #2 | ||
PM me if you want
will bolt straight in from memory, I always wanted to drop a V8 in my 73 cortina.
What colour is your cortina, the 2L with a bit of work and the 3.9 diff ratio is a rocket though.
14-05-2007, 10:36 PM | #3 | ||
Formerly FTE666
Bronze, dunno if that is the official Ford colour name, but it's what i call it
14-05-2007, 10:39 PM | #4 | ||
PM me if you want
oh ok, mine was green, a metalic green colour it was an XLE.
14-05-2007, 10:49 PM | #5 | ||
MIGHTY MAGPIES 2010
Location: yarram se vic in the shed listening to pinkfloyd and rubbing panels
lovvvvvvveeeeeeeeee the td xle's with the 250 crossflow's wer'nt much back in the day that could keep up with them
15-05-2007, 12:09 AM | #6 | ||
Formerly FTE666
mines an XL with the 4-speed behind it
16-05-2007, 12:43 AM | #7 | ||
sorry to spoil your fun but AFAIK the TC/TD's had a flat firewall with the 4 cylinder models so if thats the case youd need to modify the firewall
the 6 cyl models had the firewall tapered to accomodate the 6 cyl in the TE model all the firewalls were the same in 4 cyl and 6 cyl. other things youd need would be.. cut out the front behind the radiator as he 6 cyl needed more room so the radiator was set back in the gap there. use 6 cyl engine mounts.. possibly move the gearbox crossmember back (i know the TE's in the 4 cyl model the crossmember was a bit forward to the 6 cyl model.) just a bit of heads up info that youd have to think about if you have a flat firewall the easiest way might be to get a 6 cyl TC corty and if you have excellent interior or whatever.. swap the interior over to the new shell. Tim. |
21-05-2007, 08:22 PM | #8 | |||
As Tim said, thats right on the money |
