Old 25-05-2007, 06:19 PM   #1
Nemesis737
Straight Six
Default XG XR6 Headlight spacing
Was wondering the legal consequences of removing one of the headlights from the XG XR6 front, put some meshing and paing it to appear like a headlight, to allow more airflow into a pod filter?
Nemesis737 is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2007, 06:23 PM   #2
LUXO_8
windsor user
probably just a defect, that said you might get a fine as you would have deliberately removed it and put the mesh there...
Old 25-05-2007, 08:29 PM   #3
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
The headlights separate high and low beam units, so you would lose one - not sure that would be legal, definitely not low beam. Perhaps it would be better to see if you can get the right size light (must be ADR/E-mark approved to be legal) with a H1 bulb (which has both high and low beam) to replace both the outer lights, and duct the inner pair.
