View Poll Results: Do you wait for your car to warm up?
Yes - I wait for the car to warm up 213 67.19%
No - I drive the car in the same manner regardless of engine temperature 104 32.81%
Voters: 317. You may not vote on this poll
Old 21-06-2007, 10:29 PM   #1
Falcon Freak
Falcon Freak's Avatar
Default Do you wait for your car to warm up?
As it is winter I am curious to know if other people are similar to me. I have been ridiculed for waiting for my car to warm up before I drive. When it is very cold and the car hasn't been used for a while, I wait for at least one minute after starting the vehicle before I drive the car. Once I start to drive the car I drive it gently and don't start giving it stick until it reaches normal operating temperatures. I don't believe it is good to put a cold engine under a lot of load. Does anybody agree or do similar things?
FF
Falcon Freak is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 10:36 PM   #2
Smoke Pursuit
I take off straight away but go gentle, usually until the Oil Temp Gauge reaches operating level...
My neighbour thrashes his cars cold and it makes me shiver...
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 10:39 PM   #3
GUTLES
Adam.
GUTLES's Avatar
I let mine idle while I brush my teeth, always nice to have the heater working as soon as you take off
2004 BA XR8, Winter White, Manual, 20's, Bluepower Custom Tune, Difilippo Extractors, etc - 241.4rwkw
2007 BF Mk2 Winter White E-Gas Wagon, 6 Seater.
2002 AU3 XR6, Liquid Silver, Manual, Sunroof, LPG, Rebel Kit, BA GTP's, Momo Steering Wheel & Gear Knob.
GUTLES is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 10:52 PM   #4
Fairlane
V8 Powaah
Fairlane's Avatar
Always let mine warm up a little before moving it and avoid giving it the boot before it reaches norm operating temp.
Some mornings Warming up for me is particularily important, i live about 200m from a T-junction on a 100kmh road which i use most of the time. So i always try to warm it up before i reach this intersection as it requies a plenty of oomph to merge in.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 10:54 PM   #5
Conrad
Wheres the option for "No, but i drive it extremely gently until normal operating temperature is reached."
And i try to let it warm a bit when i can.
Also i'd love the heater to work immediately, i'd be cheering! Not that i drive really early in the morning or anything anyway.
Conrad is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 10:54 PM   #6
Falcon_Phill
1967 XR Falcon
Falcon_Phill's Avatar
Yeh sometimes. It dosnt usually start till the 2nd time after not using it for a week and it being cold, but ill give it a little idle before i take off.
Coflash.com
Falcon_Phill is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 10:57 PM   #7
BZINGA
Powered by Ford
BZINGA's Avatar
I had a neighbour that owned an xc v8 that would start the bloody thing up and let it idle for 5 - 10 minutes every morning before the sun was up, you could just about use it as an alarm clock : was great when they finally moved sleep:
I let it warm up just a little but idle out for a couple of km's.
BZINGA is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 11:08 PM   #8
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
I always let it idle for a minute or two.........drive off gently and allow for the whole drivetrain to warm up not just the engine.........usually for a couple of minutes then I drive "normally"
I always check the oil temp and pressure reading before thrashing regardless........
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 11:14 PM   #9
bodes-sh
usually by the time i start it, back out of the garage, close the garage, close the gate and get back in it's been a couple of minutes anyway...
Old 21-06-2007, 11:15 PM   #10
XCSEDAN
i'm baaaack....
XCSEDAN's Avatar
gentle till shes at running temp
then i drive it a bit harder...
XCSEDAN is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 11:21 PM   #11
atec77
FF
Poll doesnt accomodate the correct way , start and drive keeping load light until up to correct temp then thrash it
Old 21-06-2007, 11:23 PM   #12
M&Ms
M&Ms's Avatar
Start up, let it sit idle for 10-15 secs for the oil to start circulating, and drive away, never letting it rev hard until the temperature guage (guage or gage????) reaches "Normal".
Would be great if the heater worked straight away on these cold winter mornings.
Just curious, is it bad to let it hold lower gears, say 2nd, (but not exceed 3000 RPM) so temperature builds up quicker???
M&Ms is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 11:33 PM   #13
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Interesting thing here is that "operating temperature" can mean different things.
I've noticed on the GT that even though the water temp is at the operating level ( 1/4 way on the gauge ).........The oil temp doesn't really budge until about 15 - 20 mins into the drive. The Oil pressure also remains high on idle even after 5+ minutes !!!!!!!!!.........can be longer when weather is real cold.
Probably not a good idea to use the water temp as the MAIN guide to when the car is at "operating" temp.
Old 21-06-2007, 11:39 PM   #14
woodsy109
Never bother with my car as you can't really tell what temp it is anyway so a short idle and i'm off. With my bike I always warm it up to operating temp and it has a digital temp display so once it gets to 80deg i'm thrashing it.
woodsy109 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2007, 11:43 PM   #15
Gabbs
Curry in a hurry
Gabbs's Avatar
I usually get in start her up and then put my seatbelt on and start reversing out slowly. Pretty much keep the revs down till its warm then just drive normally.
Gabbs is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 01:20 AM   #16
ebxr8240
Performance moderator
ebxr8240's Avatar
Yep start it put seat belts on and drive at my normal leisurely pass...
Daily driver GTE FG..
Old 22-06-2007, 01:25 AM   #17
XR8-260
When I had my fairmont I used to drive slowly (below 2500rpm) until the engine temp got to normal. Now I drive a 15 year old volvo so I couldn't care less lol.
XR8-260 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 01:57 AM   #18
Steffo
LPG > You
Steffo's Avatar
Won't budge until the temp gauge has moved from the first line off C. Takes about 3 minutes. And then for 10 - 15 minutes drive it pretty relaxed for everything else to warm up.
Old 22-06-2007, 02:07 AM   #19
Flouro_Joe
I was looking for that option myself. The instructions that came with my shift kit clearly state: "ALWAYS WARM TRANSMISSION THOROUGHLY BEFORE UTILIZING FULL THROTTLE UPSHIFTS" :eclipsee_
Flouro_Joe is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 04:23 AM   #20
clontarf_x
I usually let it sit there for about a minute or so (normally while I go open the gates). This is only overnight mind you. If i've driven her about 5 or 6 hours ago I normally just start her up, in gear and off I go
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 06:57 AM   #21
JBomb3000
I start driving straight away but don't bring it on boost until the temp gauge reaches a certain point.
JBomb3000 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 07:34 AM   #22
Zed7fiddy
Temporary Australian
Zed7fiddy's Avatar
I said Yes, most times i do, though sometimes you just gotta get going, but ill never really push the car at all untill it has warmed up.
Zed7fiddy is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 07:39 AM   #23
shedguy
Its dirty 'cos I drive it
shedguy's Avatar
Must be an XC thing ... I do that too! : Mind you, if I don't then I would be stalling and restarting the thing 5 times before I was out of my driveway .... which I'm sure would annoy the neighbours more!
As for the ute - pffft ... it's warm enough by the time we hit the end of my street! :evil3:
Good things come to those who work ....
shedguy is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 07:53 AM   #24
Dazza XLT
Back in a Ford
Dazza XLT's Avatar
I let mine warm up and pump some oil about, as I don't drive it everyday.
Back in a Ford!
2020 Ford Ranger XLT Hi Rider!
Dazza XLT is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 07:54 AM   #25
RAREV8
Previously ScottishXC
RAREV8's Avatar
The Landau is a bugger to start at the moment- no choke and a rooted dizzy so I have to let her idle for about 4-5 minutes (once it decides to stay alight!) before I drive her otherwise it farts and coughs if you accellerate....I'll fix it once funds allow but even then, I'll wait until oil pressure is up and temp has started to rise.
Great transactions with the following members:
BJ
Gilesie
XAGTCoupe
Pilch
Aussie_afroman
Donut King
Bad Boy Benny
BAWITHLOT
Greenmachine
Pinkbits
CUZ351
OhioXB
Falconunbelievable
4VXC
Uncleraggy
FG G6 Ego, tech pack, Tropic gold 1973 Landau, Cosmic blue 1975 P5 LTD....long term project
Originally Posted by 4Vman
Im just bored of the single/narrow minded...
RAREV8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 08:19 AM   #26
andrewts
White Car Driver
andrewts's Avatar
Well, starting it and backing out of the garage takes around 1 minute, and then we just head up the hill, not much over 2000RPM, and that pretty much consists of getting the oil going. We never gunn it cold, but then again it never really warms up...
Clutch Fan + Siezed Thermostat + Winter = Enrichment Mode = 27.2L/100KM
(I voted Yes)
OzECruisers - The Ford EA-EL, NA-NL, DA-DL & XG-XH Owners Club
andrewts is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 08:21 AM   #27
Eb Barbie
Eb Barbie's Avatar
I usually drive it straight away because I'm always in a rush to get to work. If I actually am ready in time, then I do let it warm up while I wipe the mist off the windows Damm cold weather!!
Eb Barbie is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 08:26 AM   #28
james22
With da Warlords
james22's Avatar
Yeah, Always warm up the Xr before I drive for at least a minute or two. And won't get into it until I have hit Normal operating temp. I'd be lucky to drive it once a week, so I always warm it up first
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 22-06-2007, 08:47 AM   #29
OED666
OED666's Avatar
mine drives like a pig when cold... much nicer when warm
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2007, 08:53 AM   #30
webby_191189
low wagooon
I might leave it for about 5 mins while i open the gates up. But i normally drive it right away unless it is freezing cold. Mind you i only give it light throttle when it's cold.
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
