Old 29-05-2005, 08:28 PM   #1
Electra Blue
Default Capri GT 3000 V6 WANTED
As above, where would I start to look for one, the engine that is? Or is there a similar later model variant?
Trev
Electra Blue is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2005, 12:10 PM   #2
Brock071
Trev,
There's one on e-bay at the moment!
Tel, proud owner of Brock Fairmont Ghia, Build No 071
as well as my 1971 Capri 3000GT!
Brock071 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2005, 02:25 PM   #3
PULLY6
PULLY6's Avatar
What sort of money are these cars going for? I'm interested in buying one as a project car (not specifically a V6).
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust
PULLY6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2005, 06:33 PM   #4
Dale
www.capriclinic.com this guys sell new and second hand gear
Dale is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2005, 06:43 PM   #5
The Mighty Red
The Mighty Red's Avatar
Good luck trying to find a really good V6GT Capri that won't cost you a couple of limbs
The Mighty Red is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 10:22 PM   #6
v6powered
I got a pretty decent V6 Capri for around 3 grand, and it was road registered. Look into getting a four cylinder one, cause many of them are able to kill a V6 Capri, unless of course, you like the lovely burble in the exhaust as you decellerate, then, you need a V6! The Essex is really good, considering it holds up damn well for a 72.
Old 14-09-2005, 06:17 PM   #7
raaf86
hey mate i got one, capri gt v6 3 litre, comes complet with the car,
contact 0404314075
Old 17-09-2005, 01:17 AM   #8
xyute
A.k.a wolf159
The only time a 4 pot Capri would kill a V6 is if th 6 was running on 3 cylinders. Having owned 5 Capri's ( 4's and 6's ) and currently in possesion of a RS3100 I think i'm qualified to make this statement. If a V6 cant kick the hell out a 4 there is a serious problem..... Hell even my Twin Cam Cortina who's motor is a seriously worked version of the Kent 1600 used in the Capri has trouble staying wth th V6
xyute is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2005, 11:55 PM   #9
mudduck
mate thoese 4s of your must off been 4 cyl pinto goes hard revs more an lightwieght kicks *** on v6
Old 09-10-2005, 11:51 PM   #10
xyute
A.k.a wolf159
Ok.
The Pinto used in the Capri was a 2.0lt this engine with a single Weber 32/36 DFAV carburetor and 8.2:1 compression. It produced 64 kW (86 hp) and 140 N·m (103 ft·lbf). Even the 1.8 Dohc only produced 115 hp, admitedly they can produce good power when worked on.
The Essex v6 used in the is good for 142hp in baseform and around 170ft lb of tourque, and when breathed on can produce 250+ hp and a lot more tourque. So the extra weight of the v6 is of no consequence, they also will pull fairly good revs, in fact only slightly less than the Pinto you love so much.
And fyi in all the many years i've own'd V6 Capri's never have I been beaten by a Pinto engined vehicle either standard or worked over....
Old 16-02-2006, 03:10 PM   #11
Modena RS
Originally Posted by xyute
Ok.
Although I knew a guy with a blown ex-formula Ford Kent block in a Capri that would have given the Essex a good run...
Modena RS is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2006, 09:02 AM   #12
whooligan
whooligan's Avatar
I keep this brief.....The V6 is basically built for torque so where having torque is an advantage, ie hill-climb on the freeway etc blowing a 4cyl away is what the V6 does best. However, where a good worked 4cyl comes into its own is excelleration. I'm a big fan of both the 2lt Pinto and the Essex V6, I own an RS2000 and a GT V6 Capri. To compare the cars would be crawl but I'd have to say the Pinto would have the Capri off the line 10 times out of ten, but cruising at 100, then dumping the foot would see the pinto really struggle against all that torque (even with the big cam thats in my RS2000)
Theres an old saying - "there's no substitute for horses"....Which we all know is just pub talk. Having a std base torque of 260Nm at only 3000rpm the V6 makes it a pretty good start for a performance engine. Unfortunately, the cost and availaility of parts makes working up a Essex pretty much, uneconomical.
.....Oh, to answer the original question - Try placing an ad in your local Capri Club newsletter. There's usually a club member got one stashed away somewhere.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 12:43 PM   #13
buickman
buickman
buickman's Avatar
Most woud have rust in them as well. Check the car over for hidden rust in the body frame.
Panels & interior are now starting to get scarce as well. So chose wisely unless your good with the torch & mig.
Mechs are not a big issue
Old 18-02-2006, 09:02 PM   #14
bad_mk1_escort
eskie freek
bad_mk1_escort's Avatar
hey if ya still interested in 1 i have a four cylinder for sale pm if interested i want bout $850 for it
black mk1 on goin project/ toy
94 ef xr8
toyota 60 series project with 6inch lift and 35z
Xd sedan project for sale
mk1 4 door project car for sale
Mk2 4door 1.6lt for sale
bad_mk1_escort is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 09:08 PM   #15
mustang
mustang's Avatar
1.6L or 2L
1980 Coupe, Blue, 1.6L, 2" exhaust and extractors.
Oversteer Scares The Passengers , Understeer Scares The Driver
WWW.QLDSTREETSCENE.COM/
mustang is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2006, 05:47 PM   #16
bad_mk1_escort
eskie freek
1.6 and drivein
94 ef xr8
Old 21-02-2006, 06:32 PM   #17
R0BD0G
R0BD0G's Avatar
How Much r u willing to pay for 1............does it have to be an original GT..............wat Year
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 04:52 PM   #18
Electra Blue
After a VERY tidy capri v6, GT would be a bonus. Will travel for right car. (Eastern suburbs of Melbourne)
Old 20-09-2006, 05:16 PM   #19
whooligan
whooligan's Avatar
Give JR (John Roberts) from the Capri Club a call. 0409 091 252. I was speaking to him last night and he has one in good condition, just need putting back together.
Old 17-10-2006, 02:41 PM   #20
Jim5_0
I sent you a PM a while ago but have not recieved a reply.
Jim5_0 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2006, 03:52 PM   #21
cosworthfreak
cosworthfreak's Avatar
I just wanted to check if this car is available or if it has been subsequently sold. I am also interested in finding a GTV6 Capri, or even an RS3100 if I was lucky enough.
Jamie
cosworthfreak is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 01:50 PM   #22
sean.ben
I have the complete driveline for out of a gt, dismantled motor (complete) good gearbox, and the diff with tail shaft. make me an offer as i want to get rid of it all. i am in adelaide
sean.ben is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2006, 07:33 PM   #23
cosworthfreak
Do you still have the running gear Sean?
E-mail me at radioactiveman1@optusnet.com.au.
I would also like to restate my search for a V6GT Capri, RS3100/2600 Capri or even a '69 1600GT Capri.
Thanks
Jamie
