![]() Join Date: Dec 2006
I can get a Commodore diff cheap for parts
Bloke says internals are the same as AU Falcons, made by Borg Warner I remember once Ford sent me to Holden for a diff compression spacer when they had none and it was the same. Anyone know for sure, never worked on Holdens.... Thanks |
Spr Jenkins
Nah not quite, Holden have the Borgwarner 75, we have the Borgwarner 78. That being said Holden diffs from the VL through to VT? will fit in fords. You probably would only want the VL one anyway because they had a 3.7ish ratio. Skyline R31 and Pintara R31 diff gears will also fit.
Some diff places will tell you it can't be done but they know nothing. If your in Melbourne try Victoria Automatic and Differentials. How noisy it will be depends on the condition of the gears and how well you set it up. If the gears are in good nick and its set up properly it will be the same as you got now.
-Before Chuck Norris visited them, they were called "The Virgin Islands" Now, they're just "The Islands" -Mathematicians have found that due to the excessive amount of women Chuck Norris has slept with, it is guaranteed that he appears in your family tree a minimum of three times -Chuck Norris doesn't sleep. He waits. -Chuck Norris once worked as a weatherman for the San Diego evening news. Every night he would make the same forecast: Partly Cloudy with a 75% chance of Pain. |
Thanks for that
The main bit I want is the square cage piece that the star gears and shafts go in, then I can assemble an AU diff to put in my BA. Sounds like it will be worth a try |
#4 | |||
Everything that had a 6 or V8 is the BTR78 housing. Gears out of all of these are interchangable. VL's had 3.45's too. Skylines had 3.7, 3.9 and 4.11 in the Pintara.
I think you'll find that the IRS centres are different though.
What would forum's be without post whoring know it all's......... |
#6 | |||
Peter Car
#7 | |||
Purveyor of filth
#8 | |||
LOW AND SLOW
Regulator
I had VL Turbo diff gears in my EA housing. Bloody great LSD it was.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
#10 | |||
Right out sideways
L6: 3.45:1 L6 Turbo: 3.45:1 V8: 3.08:1 1988 SS Group A: 3.08:1 SV88: 3.08:1
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
