Lost keys to AU,
Wondering how you change ignition barrel on a AU. Sheer bolts you would chissel hammer them out,could u drill thru them ? Once i pull the whole ingnition barrel out,i could either replace the whole lot with a 2nd hand from wreckers or just replace barrel with new? My concern is,with smart lock smart sheild would i have promblems when replacing ignition barrel,ECU wont register to start with new ignition barrel ? cheers, |
Boost Addict
smartlock will need to be reprogrammed for new key coding or vs versa
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
Is there a code on ignation barrel or something you can give ford and ford can just cut you a new key to fit orginal ?
V8 Powaah
Yeah with a VIN number your should be able to get ford to cut you a new key- without needing to destroy your igntion barrell
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
#5 | |||
![]() I guess it be cheaper and easier than replace the whole lot and this way you still get a key for the door ? |
Give Shaun Traynor a call at Belconnen McGraths. He's the service Manager there. Tell him what you need. Just mention that you were referred to him. Butter him up, so he might give you a good deal
FG2 XR6T KIA Cerato 2022 Kawasaki Z900
you can just pop the barrel out without touching the lock mechanism...from memory you turn ign one click and there is a little button type thing ya push and the barrel will slide out....if ya using a new barrel and key you will have to get in coded by a mechanic with a good scan tool or ford.....
#8 | |||
You can buy the barrel it self for 30 bucks,so if i can just pop out barrel slot new one in,will the car work normally or will it go crazy and think its being stolen ? :-p |
T Series Club Member No24
Mate just take vin to ford get key code. Go to a master locksmith and get cut , they will also be able to program key to car. I can , cut and programmed about 120 to 200 depends on travel. Cheers Bos
1967 XR Falcon Mountain Blue Worked 250 2v , Kitted C4 , LSD , 10x14 Rear 9x14 front (LOW and FAT) had for 26 years....magnificent! FTe Venom T3TE50 No229 5.6L Manual Don't drive one! Because like so many others , including ME , you will become TOTALLY addicted. 2016 Harley Davidson Softail Heritage customized. Dead set gorgeous! |
