Old 01-01-2008, 07:43 PM   #1
BNKRPT
CAPRI IN THE BUILD
Default 71 capri build up.. need some info
hey guys, have just joined the site! i have a 1 owner 71 capri i am building up, my grandfather bought it new and has been passed onto me.
im holden through and through have a 355 clubby on nos, etc but have always wanted to do the capri up.. now its my chance!!
i have a wrecked eb xr8 sprint, motor auto trans and diff are ok, i was thinking of putting them in place, where would i find a sump etc to suit? does anyone make kits to put the efi 302 into capris?
also what is the best brake option.. even if i dont put the 302 into the capri, the brakes are terrible.. is there a way to put falcon brakes on them?
any help would be great,
thanks
scott
BNKRPT is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2008, 11:48 PM   #2
Sterling
im not the right guy to answer ur questions but most likely the falcon parts (brakes etc) wont fit on the capri, its a much smaller car.. then again nissan pulsar brakes fit a datsun 1200
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2008, 04:01 PM   #3
whooligan
whooligan's Avatar
Hoppers Stoppers here in Melbourne do a 5 stud Falcon conversion which is apparently good value for money. Castlemaine rod shop do a similar conversion.
Just out of interest, is the Capri a genuine V6 GT? If so, you might be better off leaving it well alone and source a 4cyl to do your V8 Conversion.
Heres a couple of pic from my V8 project
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2008, 04:18 PM   #4
Sterling
then you could buy falcon wheels, which there are soo many rims available
Old 03-01-2008, 02:34 PM   #5
Jim5_0
scott
EB XR8 Sprints don't exist. It's either an EB XR8 or an ED XR8 or an ED XR8 Sprint. If it's an ED XR8 Sprint then I hope it is very very crunched as otherwise you will be cutting up a rare and soon to be valuable car as they made less than 500 of them IIRC.
This would be akin to cutting up a VL Walky to use the injected 5 litre in a Torana.
Jim5_0 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2008, 09:46 PM   #6
BNKRPT
CAPRI IN THE BUILD
sorry guys its actually a eb xr8 with sprint decals! but has the quad headlight front on it , which i have sold
the capri is a 4 cyl 1600.
interesting about the brakes .. hmm got me thinking now i might find out about fitting the eb brakes onto the capri from the hopper stopper guys
does anyone know if i have to cut the firewall to fit the 302? as i looked at all the capris at summernats and they all had it cut back a bit ?
i can get it engineered in sa with the std 302 efi if i fit the falcon brakes and emmisions gear too!
71 capri in the build.. need gt bonnet and some wheels!!
Old 10-01-2008, 11:58 PM   #7
Sterling
unless u do some serious research i would just recomend taking out your engine and simply taking some measurements from ALL angles and points.
is this car road going or a garage project?
Old 11-01-2008, 02:50 PM   #8
Capri351
No cutting of the firewall is required for the 302 (and none required to slip a Clevo in there either ). You will however have to cut the original radiator panel out as it intrudes too far into the engione bay, fouling the engine.
I would recommend talking to the guys at Castlemaine rod shop and getting their Capri V8 conversion kits. This includes chassis rails, engine mounts, and crossmembers, when I did mine it all fitted well and provided a good strengthening basis for the V8. CRS also can supply extractors for the 302.
As for brakes, talk to Hoppers stoppers or CRS for upgrading, hoppers are good. I used a Datsun 120Y booster with an XD Booster for clearance, worked well. theres other options, so talk to whoever you get the brake kit from.
The swap is dead easy, so don't be afraid of it. Any more questions, feel free to PM me since I've been there and done that.
Capri351 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2008, 10:05 PM   #9
BNKRPT
CAPRI IN THE BUILD
sterling its a garage project hasnt been regoed for 6 years it will get the new driveline, interior paint and wheels etc before it comes back on the road!!
capri351 , thanks heaps for the info , i talked to crs at the summernats and they didnt seem too interested in expaining what i needed and the costs, the guy told me id need 2600 at least for the kit.. is this true? that was for the chassis kit, mounts etc,
yeah ill go thru hoppers stoppers as i did when i got my torana upgrade kit!!
might pm you mate, thanks heaps for the reply, always good to get somone whos done it before!!
Old 11-01-2008, 11:52 PM   #10
cosworthfreak
cosworthfreak's Avatar
.....i talked to crs at the summernats and they didnt seem too interested in expaining what i needed and the costs, the guy told me id need 2600 at least for the kit.. is this true? that was for the chassis kit, mounts etc....
: $2600????
The last time I looked at their site the chassis kit was around $1000 (only late last year). I've got one you can have for $500, never been fitted, still has all the bolts and mounts etc. Freight would be an issue with these though, although I suppose they must ship them from Castlemaine to various places around Aus.
Maybe they were talking about everything you'd need (chassis kit, brake kit......), but $2600 for the chassis kit alone doesn't sound right.
Jamie
cosworthfreak is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2008, 12:10 AM   #11
BNKRPT
CAPRI IN THE BUILD
hey jamie, nah was 2600 for chassis kit,engine mount kit, crossmember kit, and somthing else.. didnt quite listen as the guy seemed quite rude.. maybe thought i was wasting his time? as im young(ish) almost 21.. who knows
sending pm now jamie
Old 12-01-2008, 10:13 AM   #12
Capri351
No problem mate.
Seems CRS has the same attitude even after a management change. I got the same attitude when trying to get some info about the brake conversion. Worked it out myself in the end.
I paid about $2000 from memory and that was for everything including Bronco sump and brake kit. But that was some time ago, so I would expect a few more dollars nowadays. they probably pulled a number out of their for you, thats always a problem for a 21 yr old, been there had that.
