Irregular Member
Just wondering what the legalities are using the driving lights on say a BA XR6/8 are? There's so many cars out there now with these things and years ago I was told that it was illegal to use them in 'built up areas' etc so if anyone knows of laws preventing the use of them, please let us all know.
Cheers! |
It's illegal to use them unless in adverse driving conditions.
Cheers, Sam. |
The one and only
Here we go again......
Foobar, you might get more answers from a search as this topic turns into an arguement. They are illegal unless in poor weather or owner of a Commodore and think you are Mark Scaife.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
Mot Adv-NSW
Further to Sgt Doofey, very mild technical stuff:-
The lamp 'compliance code' shown on the lens will have on it the letter "B", eg; '02B' near the E-mark (Example; E13 or E1 etc), this letter 'B' represents certified compliance for a front fog lamps technical specification, and not for spot or driving lamps - which bear instead the letter "R", example 'HR' on the lens. The switch that operates them bears the ISO front fog symbol. The wiring and mounting of such for cars, vans and 4WD is per front fog requirement in ADR13 and NVS - which allows operation on park/low/high-beam. Traffic law governs 'use' of lamps. Driving/spot lamps operate in conjunction with high-beam headlamps only. Front fog lights are not DRL's - daytime running lamps, which on a 12volt system bear 21 watt bulbs. Complianced front fog lamps by comparision on a 12volt system bear 55watts as a maximum. TELL-TALE: A pilot lamp/telltale is option with front fogs, colour is usually green. Rear fog carries a mandatory yellow or amber telltale. ISO primary auxilliary lamp symbols you see in vehicles. 1. = Front Fog. 2. = Rear Fog. 3. = Driving Lamp
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf Last edited by Keepleft; 11-01-2008 at 12:26 PM. |
#5 | |||
Irregular Member
I leave mine on as they really do illuminate a nice wide area of the road, they shouldn't impeded oncoming drivers as I've never had issue with anyone driving towards me with them on. However, if there's a chance I might get pinged for it on a slow booking day, I will turn them off. |
#6 | ||||
BOSS Pilot
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
Lucky, lucky bastard!
183. Using fog lights
(1) The driver of a vehicle fitted with a front or rear fog light shall not operate the front or the rear fog light unless the driver is driving in fog or other hazardous weather conditions causing reduced visibility. Points: 1 Modified penalty: 2 PU (1 PU = $50.00) 79. Daytime running lights (1) A pair of daytime running lights may be fitted to a motor vehicle. (2) A pair of daytime running lights fitted to a vehicle with 4 or more wheels must be fitted with the centre of each light - (a) at least 600 mm from the centre of the other light; and (b) not over 510 mm from the nearer side of the vehicle. (3) However, a pair of daytime running lights fitted to a motor vehicle under 1300 mm wide may be fitted with the centre of each light not under 400 mm from the centre of the other light. (4) When on, a daytime running light must - (a) show a white or yellow light visible from the front of the vehicle; and (b) not use over 25 watts power. (5) Daytime running lights must be wired so they are off when a headlight, except a headlight being used as a flashing signal, is on. (6) For subrule (3), the width of a vehicle is measured disregarding any anti-skid device mounted on wheels, central tyre inflation systems, lights, mirrors, reflectors, signalling devices and tyre pressure gauges. So in a single line Fog lights - used on there own when in Fog as headlights are no good Daytime running lights - come on with the ignition but go off when headlights are illuminated Headlights - Any time Spotlights - Independent switch and can only be activated when high beam is activated. One of our club members was booked last September for this, $100 and 1 point
2015 Mondeo Trend 2.0T Diesel, Deep Impact Blue 2012 FPV GT-P 6spd Auto, Lightning Strike |
my mate got pulled over and a given a warning with his 95 320 BMW while driving with the spotlights on at night, he was told they are illegal to have on unless driving in very poor conditions
The Origional, The Best
i've got driving lights in mine, aimmed down slightly, and use them whenever my headlights are on. haven't had a problem, neither have my mates, but then again, we live in Darwin which is slightly behind the times
Current Mods 2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts Future Mods Lowerage on KingSprings Lows | Engine...Period | Sounds System I Use And Recommend F1 Tyres And Wheels On The Gold Coast Proud Supporter of Beat The Heat (NT)
#10 | |||
let it burn
I guess Im saying it depends on circumstances on whether they are a danger to oncoming traffic. Some vehicle driving lights seem to be designed badly so the effects are more common, while others seem to be designed well and dont produce the same problem as much. The law is clear, they are ILLEGAL to use unless weather conditions are poor. |
i just turn mine on when the car is freshly washed and i want to impress people. never been pulled over
#12 | |||
Bringing the Spartan back
East Coast Suspensions Road - Race - Performance & Prestige Car Service BOSS 5.4L Silicon hose kits for sale BA/BF FPV parts for sale The only negative thing in your life should be camber Blue Power Racing Enhanced Chris & Craig - Thanks! |
OzECruisers FTW
I got pulled over for mine we i was driving on a rural rd, goin to see my mate, and the copper said dont drive with them on if im in a suburban st or near a bult up area. (my excuse was my headlights are absolutly shocking and i need these to see if there are any animals on the sides of the road)
Dont waste time... or time will waste you EB II GLi, AU 4lt and auto conversion :evil3: , 17" mags, Tub's on the way, Sound system, Tinted windows, Lowered. |
#14 | |||
Page 233 of the PDF. (Page 209 of the document)
Cheers, Sam. |
#15 | |||||
Mot Adv-NSW
Sgt Doofus highlighted a link to ARR's in which existing ARR-217 'rear fog lamps', has been updated to include the same prohibition-of-use. Most states will have this contracted mid-late 2008 in full. Grum wrote:- Quote:
Each state driver handbook now imparts much the same advice. Tristo 4.0 wrote: Quote:
Remember this; a front fog lamp bears a forward range typically 10 - 35 metres to a maximum of around 50. Its design is such that it also has a hand-fan shaped beam pattern, designed to show up the close-in edges of the roadway better than even low beam is able to achieve, when under seriously reduced visibility conditions. Reliance on front fog lamps to get you out of trouble in clear conditions at night in misguided. Rem this basic - at 100km/h your moving at 28 metres per second, that gives you precious little time to react to wildlife or insane MP's swaggering by the roadway, by the time you've spot Skippy or wombat, or MP off to the left or right and closing, - you've hit it. Too much foreground illumination reduces your eyes ability to see potential trouble residing much further out. By comparison, standard modern halogen lamps on high-beam will see 170 - 220metres. Add a set of driving lamps and you can range out to say 300-500m plus! Front fogs are a luxury item and some compliant units perform better than others, but,- they are specifically designed for a purpose; if visibility is attrocious - they really help you see ahead if you switch off low-beam. That lighting action cuts glare and allows your front indicators to be seen more clearly by lead and approaching traffic. Their design purpose is only for use in rain, heavy fog, bushfire smoke, duststorms, and are particularly excellent when driving in falling snow, the worse the visibility the better these things are for you. The primary 'lighting' defence against low visibility crash occurence however remains the rear fog lamp, which will be mandated on new market vehicles 'one day'.
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf Last edited by Keepleft; 11-01-2008 at 09:26 PM. |
#16 | ||
OzECruisers FTW
Yeah, I resolved this problm today by buying a set "XENON BLUE performance halogen globe
#17 | |||
Mot Adv-NSW
Compliant headlight halogen bulbs will bear E markings on the steel body. Some bulbs do not comply, and so quality in performance is not guaranteed. What you'll notice with say the Narva 'blue' bulb is a 'whiter-white', kinda ice white, but the beam range stays the same, its just more defined at the edges, the extra white improves your vision of linemarkings, road markers, reflectors and alcohol fulled members of parliament who might be asleep in the middle of say a rural road somewhere. Approaching traffic see them generally as a whiter-light, than the say of the 'creamy/duller' standard halogen type. This does not equate necessarily with undue or out of compliance - glare! * Never raise the wattage of a front fog lamp in particular, you need less glare not more with these. "All Weather" variety bulbs are recommended for these, they have a slight yellow 'tinge'. * Increasing a headlights wattage can technically put the headlamp out of compliance, since lamp compliance is only tested at regulated standard wattages for each lamp function. * With halogen lamps, you can legally use the Plus 30, Plus 50 etc variants. Good brands are Phillips/Osram/Narva/Hella. Do take a look at those some day.
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf |
#18 | ||
OzECruisers FTW
* E Marked and legal for road use [E1]
Say's that on the packet so i guess they would be ok, and they are the same wattage as my stock globes.
#19 | |||
HSV - I just ate one!
#20 | |||
Boost Happy
#21 | |||
LOW AND SLOW
#22 | |||
#23 | |||
LOW AND SLOW
#24 | ||
It should be up to the drivers choice whether they have there foglights on or not . I use mine whenever I feel like it had no problems. Usually just at night or dusk.
BA 03XR6T, 968's, SS CAI, PWR Cooler,Nizpro valve springs, BMC,Typhoon 18's, Brembos, 3 1/2' cat back Future mods Blisten shocks and King springs.391rwhp |
#25 | |||
let it burn
#26 | ||
If youve got em you might as well use them. But I never use them during the daylight hrs.
#27 | ||
I see police cars driving around with them on up here all the time.
#28 | |||
Mot Adv-NSW
The topic is covered. If you want to use your fog lamps day or night in clear weather, do so, eventually you'll get picked up, and often repeatedly flashed by other traffic for doing so. Much here to do with 'attitude', all ties in the ignorance of the front fog light topic, (bad driver training/not reading driver handbook) and how they are arrogantly used as a result of that, and that is where the attitude is, goes in a loop, but then you get the dopes who know they shouldn't, but do. Small schlong syndrome mebbe.
#29 | |||
FORD DRIVERS WANTED!
11/03 fpv pursuit # 255 "silver bullet" KYLEE MOLE travel agency "she goes she goes she goes and then she went" |
#30 | |||
Boss power
:the_finge BOSS 260+ :the_finge |
