Old 21-01-2008, 03:21 PM   #1
XR6 Hulk
Default Which car responds better to mods? XR6T or LS2
Armed with different cash amounts below, which car is better to mod?? Assume at each stage thats the maximum amount the person will spend..
1. $1500
XR6T, get a custom tune, injectors? 250rwkw? Mid to low 13s
LS2, custom Tune, OTR intake 240rwkw Mid to low 13s?
2. $3000
XR6T, above plus, valve springs, exhaust mod? 280rwkw, high 12s
LS2 above plus Full exhaust system, 255rwkw, low 13s?
3. $5000
XR6T, above plus, fuel pump, actuator, intercooler, 310rwkw, low 12s
LS2, above plus, cam. 300rwkw low 12s?
I reckon both are about even for responding to mods? what do we think bang for bucks? Am I right or is one better to mod than the other...
XR6 Hulk is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 03:24 PM   #2
id go the ls2. more scope for future work and a sweet note
Old 21-01-2008, 03:25 PM   #3
DBourne
DBourne's Avatar
i might be wrong, but i would think that even with $5K to burn, the T would respond better than the wheezer.. but i could be way off
flickr
DBourne is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 03:39 PM   #4
Steffo
LPG > You
Steffo's Avatar
What does the Windsor V8 have to do with GenIV LS2 vs Barra240T?
Old 21-01-2008, 03:45 PM   #5
Fev
Fev's Avatar
the turbo definately. 5k - exhaust, intercooler and intake, underdrives, thermo flash tune will get you into 12's
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 03:48 PM   #6
Josh_XC
Yeh a turbo i would have though will respond better to mods that a v8.
Originally Posted by MYLO_XR6
i dont like motors that come in the same size as milk and orange juice
Bionic BF XR8 - 6 speed manual, reversing sensors, premium sound, GT starter button. 218rwkw - Got to love the BOSS!!
Josh_XC is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 04:09 PM   #7
Quicksand
Lucky, lucky bastard!
Quicksand's Avatar
1. $1500
2. $3000
3. $5000
Hmm could be biased but i too lean towards the T. Hell i got 260rwkw from a $195 tune let alone spending $1500 (no i haven't updated my signature yet ). I was told by my tuner that bigger injectors alone would get me close to 300rwkw which is straight into the 12's
haven't done much research beyond that so i can't really comment but if you want a contrast, my friend has so far put $7000 into his LS2 SS and his best time down the 1/4 mile is 12.8 (though admittedly traction is stopping him from seeing a 12.5 - the recommended time for his power so to speak). It would cost me far less than $7000 to get into those kinds of times. I don't know what he has done to his car but it sounds lumpy, loud and goes fast heh
2015 Mondeo Trend 2.0T Diesel, Deep Impact Blue
2012 FPV GT-P 6spd Auto, Lightning Strike
Quicksand is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 04:15 PM   #8
RavenLS1
$ for $, the turbo will win hands down.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 04:28 PM   #9
Mr Turbo
Mr Turbo's Avatar
You cant go past the Turbo! Best value bang for buck... for example ive seen and edited stock T (only mod was airfilter) go down Calder on factory rubber and did an high 12 pass!!!
Rob... :
11.567 @ 120mph "with stock intercooler and internals at the time..."
COME CHECK IT OUT = http://p4.forumforfree.com/fordforumoz.html
Next project: Stronger internals = 400rwkw's = easy 10's :1syellow1
Mr Turbo is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 04:31 PM   #10
XR6 Hulk
But what ive described, the outputs seem about right, they appear pretty close?
Old 21-01-2008, 04:46 PM   #11
Quicksand
Quicksand's Avatar
can't vouch really for the LS2 but your first listing to me is a bit off the mark. 250rwkw can be achieved easily with a tune alone (in my case it was $200) which will yield a 13.2 or 13.1 1/4 mile time (as i have seen occur down at the drags with this kind of power in the BF series). If i spent $1500 on my car i would be closer to 300rwkw (bigger injectors alone (not sure on the $$) with a custom tune ($400 from BPT) would get me close to 300rwkw)
Haven't really delved into the rest of the mods yet so cant comment maybe someone else who has taken on the other mods has more of an idea?
Old 21-01-2008, 04:50 PM   #12
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
I'm yet to see an LS2 pull 130mph terminal speed at the strip with bolt on mods, the Turbo wins hands down.
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 04:56 PM   #13
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Turbo!
Old 21-01-2008, 05:04 PM   #14
5.4 GT
5.4 GT's Avatar
L98 or L76 you mean? SS' don't have LS2s.
5.4 GT is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 05:09 PM   #15
5.4 GT
5.4 GT's Avatar
1. $1500
2. $3000
3. $5000
All these figures are so wrong for the LS2 that its not funny. We are talking about the same engine aren't we? The LS2 was fitted to the last VZ HSVs and the new VE HSVs. In VE guise they make 307kw at the wheel or around 230-250rwkw stock...
Old 21-01-2008, 05:17 PM   #16
XR8-260
I've heard that the L98 responds better to mods than the LS2. There are a few L98 6.0L SSs that run high 12s with OTR, maffless tune, full exhaust.
I know of a manual SSV that has run a 12.0 @ 113.5 mph. Not bad for a car with only bolt on mods.
Mods: OTR, Xforce full exhaust, maffless tune, underdrives, tex, and 3.7 diff.
XR8-260 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 05:18 PM   #17
Quicksand
Quicksand's Avatar
aaah ok VZ SS does that help?
Old 21-01-2008, 05:18 PM   #18
5.4 GT
5.4 GT's Avatar
That it does.
Old 21-01-2008, 05:18 PM   #19
5.4 GT
5.4 GT's Avatar
Yeh that would be the L76 then.
Old 21-01-2008, 05:19 PM   #20
Quicksand
Quicksand's Avatar
ohhh ok cool cheers for the clarification
Old 21-01-2008, 05:23 PM   #21
TUF270
BACK IN AN FG TURBO
TUF270's Avatar
a VE SS makes 270kws at the flywheel. GTS and Clubby make 307kws... and we are only talking about the VE SS v XR6T arent we? so the engine in the VE SS is that an LS2?
TUF270 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 05:28 PM   #22
XR8-260
The XR6 Turbo is ahead at the moment IMO. The L98 has not been around for that long and there is more R&D to be done. It was relatively simple and inexpensive to make big power from the LS1 and the L98 has shown signs of even greater potential.
Old 21-01-2008, 05:35 PM   #23
5.4 GT
5.4 GT's Avatar
VZSS = L76
VESS = L98
VZ (last)/VE HSV = LS2
Only the HSVs have ever had the LS2s in Australia.
Old 21-01-2008, 06:28 PM   #24
DougM
My BAmk2 XR6T got 250kw at the treads with F6 CAI and custom tune only.....At the same time fuel economy was even better!!!! My first time ever at the drags I got a 13.4!! I was Happy. At the time I got my tune done there was an SSV VE with about 5k worth of mods(custom tune, CAI, full exhaust including headers) and got 248 rwkw.....I spent $1300 for my mods!!
DougM is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 06:42 PM   #25
Grechie
Grechie's Avatar
sorry for my ignorance, but what is a L76 ? and a L98 ? is the L98 a 6.0 Litre? what kind of 6 litre ? whats the difference between an 6.0Litre L98 and LS2 6 Litre ?
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 06:53 PM   #26
DDXR6T
DDXR6T's Avatar
Turbo - Everyday of the week. $ for $.
DDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 11:23 PM   #27
Angeldust
Angeldust's Avatar
u can add a turbo to an 6ltr v8, but u cant add more cylinders to a turbo 6.
Z series Clubsport HRT edition..
e46 320ci 2.2ltr Stocko
Angeldust is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2008, 11:37 PM   #28
Steffo
LPG > You
Steffo's Avatar
Yep, but converting the LS2 to Turbo completley destroys the value for money, bang for bucks equation. Factory boost will never lose the bang for your dollar battle.
Old 22-01-2008, 09:41 AM   #29
RATT
In a Pug..
RATT's Avatar
Turbo should respond better, and that's the main response there'll be on AFF.
Where can we get this done?
RATT is offline   Reply With Quote Multi-Quote with this Post
