Old 08-02-2008, 10:17 AM   #1
F-Series
Default Looking for Info on F100s
Hi guys
This is my first post, I hope I've put this question in the right Section?
I have an '85 F-100 LWB with a 'Safari' Canopy Conversion (walk through). I'm looking to strip it for a full re-spray and I'm trying to find out if it is possible to replace the water seal between the cab and the canopy (custom to that company). I've tried to locate 'Safari Canopy & Conversions Pty Ltd' who built it. But with no luck. Does anyone know if the company closed down or moved or maybe someone else may have taken over these conversion?
F-Series is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2008, 10:41 AM   #2
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
Never heard of the company, but perhaps if you took the seal down to a seal-shop (that's the technical term..), they'd be able to supply you with something the same...
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2008, 10:50 AM   #3
atec77
Originally Posted by F-Series
Hi guys
A quick scan of the asx produced
http://oceania.manta.com/coms2/dnbcompany_5jt965
Old 08-02-2008, 11:13 AM   #4
F-Series
Thanks atec77, I tryed them and it turns out to be a fabric company. Even the yellow pages & white pages don't have listings for them. My guess is they've closed down.
These are the canopies, (below) there are so many around I was hoping someone had taken it over under a different name?
Old 08-02-2008, 12:11 PM   #5
The Yeti
The Yeti's Avatar
it will no doubt just be pinch weld with a round rubber on it, if you have a sampel why not try the grippy rubber co or simular? I think Clrak rubber may do this sort of thing off the roll as well
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
