23-03-2008, 08:13 PM | #1 | ||
VFII SS UTE
according to wheel's mag hsv is to get the vett donk for the r8,
for a second lineup for the w427 gts. unlike the w427 two hundred a year jobbie this is destend as standard equipment. your thuoght's???
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
23-03-2008, 08:23 PM | #2 | ||
Fantastic, plenty to choose from if your in the market for a very nice high performance aussie car.
23-03-2008, 08:41 PM | #3 | |||
24-03-2008, 11:09 AM | #4 | |||
Regular Schmuck
Other than that, having a rough time deciphering what you're actually trying to say. I've tried to work it out, R8 is getting the Vette engine for a second attempt to release a 427 GTS? But the LS1 is a Vette engine. Now the second bit I'm not quite sure about. Destend, destined? The R8 is going to cost $200k or the old 427 was going to cost $200k a year? What's going to be standard equipment? I'd assume an engine is standard equipment in most cars. Skip.. here Skip.. where's Sonny...? |
24-03-2008, 11:21 AM | #5 | ||
VFII SS UTE
the r8 will be priced as per usual, ls3 is standard equipment on all hsv.
24-03-2008, 03:18 PM | #6 | |||
Regular Schmuck
LS3 standard on all HSV's but you seemed to indicate that only the R8 got the LS3 in your first post? So does this mean they're dropping the standard Clubby? |
24-03-2008, 03:21 PM | #7 | ||
I believe the LS3 will replace the LS2 V8s in the Clubsport, Clubsport R8, GTS, Senator, Grange etc.
24-03-2008, 03:22 PM | #8 | |||
EDIT: Or i could be completely wrong... |
24-03-2008, 03:41 PM | #9 | ||
Hoon (I wish!)
Phew - was afraid the FPV GT would be looking at going up against a 327kw HSV. Its apparently kept at 317 because they didn't want to have to rework the diff and driveline completely (according to wheels).
I want an FG! : If only I were old enough :
24-03-2008, 04:39 PM | #10 | |||
The following from mid April will be on sale with the 317kw LS3 6.2L V8: Clubsport R8 Maloo R8 Grange Senator GTS Then at around $125k powered by the LS7 7L V8: W427 As said the current E series has been capped at 317kw due to driveline constraints and torque remains the same, although the torque curve is even better than on the current LS2. Expect 327-330kw with the VF update when they are able to wind the engine up. Expect the LS3 to hang around until the next all new Commodore as it is the last of the Gen IV (along with the LS9) range of engines. Like the LS1, it has plenty of room for improvement (LS1 started at 220kw, ended at 260kw). |
24-03-2008, 04:44 PM | #11 | ||
FG F6 should be capable to take it on...hopefully
24-03-2008, 06:44 PM | #12 | ||
LPG > You
If MOTOR's claims of 315kW for the new FPV GT are true then... its about there.
LPG Lovers Association President & Member #1. : |
25-03-2008, 12:52 AM | #13 | |||
25-03-2008, 12:57 AM | #14 | |||
does this also mean the base model V8 is going to get an upgrade? (Omega -> SSV) |
25-03-2008, 12:59 AM | #15 | |||
Solution Was Boost 4?, 6 & 8
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
25-03-2008, 01:01 AM | #16 | ||
Is everyone certain the GT will have 315? I hope FPV at least quotes 320 .
25-03-2008, 01:02 AM | #17 | ||
The LS2 in the Corvette had 300kw and the LS2 in the HSVs had 307kw.
The LS3 in the 08 Corvette has 325kw and in the HSVs will only have 317kw? Doesnt sound right to me.
25-03-2008, 01:39 AM | #18 | ||||
King of the Fairy's.
It may also have something to do with marketing, It gives them a massive change to add in for the next series.
25-03-2008, 02:51 AM | #19 | |||
LPG > You
297kW 530Nm in the VZ HSV's. 307kW 550Nm in the VE HSV's. The difference? Exhaust systems for each vehicle, intake setup in each vehicle. The power won't be 100% the same between three totally different vehicles. Pretty easy to figure out. 324kW 575Nm for the LS3 Corvette, by the way.
25-03-2008, 08:31 AM | #20 | ||
Regular Schmuck
I wasn't aware they dropped the standard Clubby, seems like a huge mistake to me, but oh well.
There are plenty of modded LS1's running the standard driveline and pumping out bigger numbers without fault (even though I did have a tailshaft issue that eventually killed my diff but allowed me to install 3.91's guilt free...) so is it a case of playing it ultrasafe or is that just rumor as the reason? |
25-03-2008, 08:39 AM | #21 | |||
25-03-2008, 11:49 AM | #22 | |||
I dont know of 1 LSX/Commodore owner having that sort of power Jim
I got Whoosha to do it e |
25-03-2008, 07:02 PM | #23 | |||
Peter Car
The April release of the LS3 sounds like a load of crap to me, because thats only a week away and yet HSV have said nothing? If they were releasing it they will spend millions to tell the world in typical Holden fashion. Why would they wait so late, when they already have a waiting list, as its not like they have to sell all the old stocks of LS2, cause there really shouldn't be many. If you ordered one right now by the time you got it, it would a few months till you get it. Surely they will wait until the series II is out in October? |
25-03-2008, 07:41 PM | #24 | |||
Its All In Your Mind
BF R Spec No 284 Winter White ZF Auto P/West: Stage 2 Cooler, Plenum, & Surge Tank, Plazmaman 3" Intake & Dry Cell, Whiteline Swaybars, 1000id Injectors, XFORCE 4" Dump, 5" CAT & Twin 2.5", W/Gate & 12lb Act, Kompact BOV, Bilsteins, King Springs, Full Nolathane Bushes F & R, Braided Brake Lines, Crow V/Springs, Pole Position Bling........ Xtreme Tuned: 375 RwKw (502 RwHp) & 820 Nm: Whhooooooosssssssshhhhhh HSV HUNTER !!!!!!!!!!!!! BA Phoons 013 and 333 Gone |
25-03-2008, 07:46 PM | #25 | |||
5.4L V8
Thats exactly right mate,if ya dont like it mod mod mod. A tuned f6 or blown boss will make mince meat of any factory hsv. |
25-03-2008, 08:28 PM | #26 | |||
25-03-2008, 08:29 PM | #27 | |||
AFAIK there are no plans for a Holden based power upgrade until the VF. They'll just have to cop the power deficit to Fords XR8 on the chin until then. |
25-03-2008, 08:31 PM | #28 | |||
This is counted as a running change, not series change. |
25-03-2008, 08:38 PM | #29 | |||
You dig, we stick!
"....You don't put the car through engineering" - Rod Barrett. |
25-03-2008, 09:32 PM | #30 | |||
Peter Car
