Old 21-04-2008, 12:15 PM   #1
xr8 5.0
ED xr8 5.0l
xr8 5.0's Avatar
Default who has the quickest 5.0l EB-ED
I have a fairly quick standed short block ED xr8 and want to know if there is anyone else running an EFI EB-AU that has gotten into the 11's or the 10's and who is the quickest. On the week end I ran an 11.10 @ 121.6mph at the willow bank Tin Top titles with a 100hp shot of NOS and have gone 12.02 @ 111.8mph N/A. I hope to have this in the 11.8's N/A and 10.8- 10.9"s by the winternationals.
ED xr8, STD 5.0l short block
AFR165 alloy heads
11.92 @ 113.5mph N/A
10.98 @ 122.2mph 100hp nos
377 RWHP @ 5900rpm N/A
No longer bottle fed, now with boost
9.67 @ 144 mph on 22psi
xr8 5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2008, 03:57 PM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
Benny Gatt !!!
Daily driver GTE FG..
Old 22-04-2008, 04:00 PM   #3
adxr8
Rebuilding the ED
adxr8's Avatar
At the moment, with a standard bottom end i think Brett is the man.
ED XR8 In for a rebuild
347 Dart block:All the Scat goodies, Edelbrock Victor Jnr's, Trickflow manifold and Vortech on the stand/ work in progress
adxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2008, 07:15 PM   #4
xr8 5.0
ED xr8 5.0l
xr8 5.0's Avatar
Ok what about strockers, dart based or std block, is there any one that has ran a 10 sec 1/4, I am talking about street regoed cars here, when I run mine it is with full interior.
AFR165 alloy heads
Old 22-04-2008, 08:55 PM   #5
schnoods
schnoods's Avatar
I hope I can add to this list in about 6 odd months, going to do the top end and up the boost. :
A philosopher is a person who finds a problem for every solution . :Reverend:
95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph
Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's
1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored.
schnoods is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2008, 08:58 PM   #6
adxr8
Rebuilding the ED
adxr8's Avatar
Do it schnoods, that manifold should be working a treat!
Im working on mine but dont expect to be in the same class....
Old 22-04-2008, 09:24 PM   #7
xr8 5.0
ED xr8 5.0l
xr8 5.0's Avatar
Hey schnoods what heads are you running are they stockers. What times have you ran so far
AFR165 alloy heads
Old 22-04-2008, 11:34 PM   #8
schnoods
schnoods's Avatar
Manifold is great! Thanks again for it mate, will be holding up well further down the track.
Hey schnoods what heads are you running are they stockers. What times have you ran so far?
Well I will be having a run tomorrow, perfect timing for that question. Im hoping just to nudge a 13. Next step will be either 3.9's or 4.11's. Heads are stock e7's, basically unopened motor bar the manifold. Will be going a set of AFR heads, dont know what size yet as Im unsure of what I want out of the motor yet. I am contemplating an aftermarket block 347 stroker and winding the blower up to 15 psi, or maybe seeing if I can destroy the stock block instead.
Have taken it once down, 14.49 with a slipping auto. Auto has been rebuilt so hoping for a better time.
Im sure though, EBXR8240 has dibbs on most of us, wonder what it would do with a good set of slicks.
Old 23-04-2008, 02:47 PM   #9
xr8 5.0
ED xr8 5.0l
xr8 5.0's Avatar
with anything bigger then the AFR165 the valve notches in the piston may need enlarging on the stock pistons. This wont need to be done with Trick Flow twisted wedge heads
Yeh ebxr8240 has me on MHP
AFR165 alloy heads
Old 24-04-2008, 02:00 AM   #10
ebxr8240
ebxr8240's Avatar
Its blooody traction...
One day I'll get e/t and mph right .. So far its fast mph low E/T or reasonable E/T and slow MPH... Apart from my driving the original 3550 gear lever mechanism isn't good, its converted to TKO600.. The clutch pedal is very long since twin plate fitted..
I can't slam from 1st to 2nd as clutch seems to grab and I have to pull HARD to get it out of gear!! I'd love to fit a powerglide in there for a couple of runs!!! Tony Dominello nearly talked me into it... Its the front brakes thats preventing me from fitting X plies all round..Run with street M/T's...
My son will be there very soon with his C4 Dominello manual 3000 converter and decent 28" slicks ...Will be interesting in his EB / AU T04Z turbo Fairmont..
Old 24-04-2008, 03:07 PM   #11
xr8 5.0
ED xr8 5.0l
xr8 5.0's Avatar
This sounds interesting let everyone know how it goes. What track do you go to.
Do you know if anyone in Oz has ran a 10 in an EB-AU v8 or what about in the 11's for N/A combo's.
I could run a 10 using a 150shot but I like N/A power as well so before the winternationals at willowbank i'am going to do some port work on my AFR165's I hope to pic up about 20cfm this should get me in the 11' N/A and 10's with the 100 shot
AFR165 alloy heads
Old 24-04-2008, 10:11 PM   #12
ebxr8240
ebxr8240's Avatar
We live about 3 Klrs from Wsid...Surprised they run last Wednesday night...
Been showers all week...
Old 11-03-2009, 11:21 AM   #13
XT302
Cant find the details right this minute, but Bob Kotmel in Stage Write in Street MAchine often talks about Stuey Fenner ED XR8, I believe it is a trickflow top end 347, auto (4spd convertor?) with 3.89s high 11's on street tyres from memory.
No times mentioned here?
http://www.dailymercury.com.au/story...ck-at-palmyra/
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2009, 01:20 PM   #14
jcxr
Tribal Elder
jcxr's Avatar
Isnt it good to read about Drag racing results in their local paper. All we get in Vic. is about illegal street racing and hooning.
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2009, 11:16 AM   #15
Sprint347
Tickford
Sprint347's Avatar
I had a pretty quick stock/unopened 5.0 that did 14.1@97 at the Kwinana motorplex in '04
ED Sprint, base timing advanced 4 degrees, k&n, U98, otherwise unopened 130,000km old 5.0
It's a 5 speed, I tried the bag of ice on intake (no effect) and had 3.45 instead of 3.27 gears.
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD
AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD
BA XT
SZ Territory TS RWD TDCi
Sprint347 is offline   Reply With Quote Multi-Quote with this Post
