Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Coupe Club of Australia > Coupe Restoration & Build
Old 25-05-2008, 09:36 PM   #1
MEANXBCOUPE
injection is nice, but...
MEANXBCOUPE's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing the Helicoil article
Default MEANXBCOUPE engine build up.
Hello people!
Welcome to my new thread.
I thought that I'd do a thread to cover the build up of the new motor for my '74 XB Coupe. First I'd like to thank Col and Dave for helping with the positioning of the thread.
I dont frequent the Clevo site too much, where it really should have been before the openning of this new build up section and prefered this thread to be in the Coupe Club section any ways. Got a soft spot for the club you see.
Thanks guys........
OK, so a few people may have seen my car in Street Machine presents, Australias toughest Fords.
Cover car, yeah.
The photos and artical were taken back in June last year.
I attended motorex in July, about 2 weeks before the issue hit news stands.
A few weeks later I attended the NSW All Ford Day at Warick Farm racecourse, but, with a dark secret..... (play suspencefull music).
The week previous to the All ford day, The car was back at my workshop for a few adjustments, panel gap wise. It was a Friday night and a barby wasput on at work for the boys, we were packing away customer cars for the night. Mine was the last put away, so a burnout was in order!. Long story-short. Im now bulding a new motor after I struck water.
Truth be known, The car was sounding off before the " testing" started, maybe a small ignition issue or something, so ive got only myself to blame.
Motor before big bang
So now you know, It had a blown motor in more ways than one!! That explains the tilt tray.
Anyways, Im going to follow the progress of the new motor build up and post any updates here for your enjoyment. I dont pretend to be a gun engine builder but over the last 18 years Ive allways done my own work. This is the first catastrophic failure to date. Yes ive broken down and stuff like this but never lost a motor before.
That was probley my biggest worry before the motor was pulled down, did I screw up??? What did I forget to do???. Now I know.
The car came back to my house after All Ford Day, where it has remained since.
Dont get the idea Ive slacked off and waited 9 months to fix it, Ive been busy you see. Early September seen the arrival of my first born, Lachlan, and gotta say, Both Tracey and I have not stopped (or slept) since. The coupe has taken a back seat for a short time till we settle a bit with Lochie.
OK, nuff of the dribble. Motor got pulled from the car in late December.
Empty bay. :
Here we see an engine block, You may notice a hole, this is bad, bores should not have holes!!!. Check out the wall thickness. Measured in at 0.032", good ad for sonic testing. FYI other side of bore measured at 0.250", Core shift.
Number one cylinder.
Here is a picture of the crank and rod!
And piston and rod!
Basically, too little wall thickness plus 0.030" bore plus 10 pound boost = a total loss of motor.
I kept the following parts.
Rocker covers
Manifold
Blower
Carbys
Water pump
Pulleys
Dizzy ( although its bent the shaft its custom made so I'll need to fix it.)
Sump ( 7 holes in total, kept it for the above reason, custom)
The block is stuffed ( and now land fill) Allready 030" over, no point sleaving it. Number dont match anyway and isn't a GT block
Crank is bent, wouldnt rotate in the block.
One piston shot, it "fell" into the hole in the bore, jamming it snapping off the rod.
Rods, junk.
Cam, broken in thre places due to the broken bit of rod beating the crap out of it.
Dizzy, bent drive shaft due to the cam twisting in the block putting pressure on the shaft, I'll fix it as said.
Heads, not too bad, but a few bent valves, we go into this latter.
Any way thats it for now.
Hope you follow the journey!!!
Cheers Gary.
MEANXBCOUPE is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2008, 09:41 PM   #2
Geez Louise
Awesome
Geez Louise's Avatar
Location: In my own little world..Everyone here knows me :)
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind the scenes things that help the community.
Great read Gary. I was just reading about your car again today in the mag.
I can't believe how much damage has been done. Looking forward to seeing the progress though. Best of luck with it all.
Col
Geez Louise is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2008, 09:46 PM   #3
Electric XY
good luck with the build, awesome looking coupe. i allmost saw your car at motorex but i could not get any where near it from all the people gathered around it .will it be at the next motor ex or the all ford day.
Electric XY is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2008, 02:41 PM   #4
XBCoupeNZ
You don't mind if I print out a life size colour print of your motor and tape over my engine bay do you? :
Isn't a bore, just a big hole? Guess its not good when the piston goes sideways eh .. was a very pretty engine though.
XBCoupeNZ is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2008, 06:13 PM   #5
MEANXBCOUPE
Thanks Col for the support.
Dont know of the finish date yet. Got heaps to do. May be at AllFord Day again...
Yep a bore is a big hole??!!
Old 26-05-2008, 09:10 PM   #6
Auslandau
335 - STILL THE BOSS ...
Auslandau's Avatar
Well what can I say! Thats a hell of a hole!! With a bay like that and a near fresh start, imagine the huge cubes that would fit without the restrictions of the towers!!!
Very sad to see and dread something like that happening to mine! Those last minute bits of fun can end in tears ....
| [/url] |
'73 Landau - 10.82 @ 131mph
'11 FG GT335 - 12.43 @ 116mph
'95 XG ute - 3 minutes, 21.14 @ 64mph
101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong!
Clevo Mafia
[SIGPIC][/SIGPIC]
Auslandau is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 07:56 PM   #7
fatasslandau
the money box
fatasslandau's Avatar
and look no scratches in engine bay. JUST AS WELL OR I'LL HAVE TO COME ROUND AND! AND! watch you fix it. i've got the dates for all ford day maybe it'll be ready for you to win all the trophy's again [like it should f#%k it's nice] if i can help with anything let me know
fatasslandau is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 08:41 PM   #8
MEANXBCOUPE
Dont joke about scratching the engine bay. It's NOT FUNNY. Its gotta go back in yet.
Old 28-05-2008, 08:47 PM   #9
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
So you replacing the block with aftermarket ?
What specs ?
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2008, 01:02 PM   #10
Uncle Raggy
Uncle Raggy's Avatar
Bloody core shift. You just can't trust pattern makers and foundries can ya! Lol, I shouldn't say much since I am a patternmaker by trade and still work in a foundry : The only block I've ever made a pattern for was a 4 pot aluminium Ford based speedway motor, not too much of an issue with core shift, it's all sleeved anyway
Uncle Raggy is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2008, 01:59 PM   #11
Fev
Fev's Avatar
ouchies, i cant wait to see the new motor. doin anything different? other then fixing the first problem ofcourse :P
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2008, 07:27 PM   #12
fatasslandau
the money box
its all good mate i'll bring heaps of bubble wrap and beer.
Old 29-05-2008, 07:38 PM   #13
fatasslandau
the money box
sonic testing works sometimes i went through 3 clevo blockes before we found one up to the task.although one block passed sonic test went to the machine shop then passed on to engine builder only to have the bore leak when he was cleaning with gerni. so who stuffed up. the sonic tester or machine shop? needless to say next one was scrutineered very closely
Old 30-05-2008, 04:10 PM   #14
MEANXBCOUPE
: ohhh, beer you say??? :
Old 30-05-2008, 08:28 PM   #15
fatasslandau
the money box
ohhhhh yes beer just packed the fridge with some nice cold ones just waiting for me to bring em over and consume while we put a certain engine in
Old 30-05-2008, 09:16 PM   #16
motorcycles4eva
love the xa's
motorcycles4eva's Avatar
nice car even without engine.. sad to see the damage but good luck with the build.. if you don't mind a silly question... was it a 351 block? if so when borred out and the walls are so thin, would you or could you re do a 460 blown engine?? i mean is it worth it in different ways?? (im learning about engines sorry...)
cheers..
motorcycles4eva is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2008, 10:49 PM   #17
MEANXBCOUPE
Update.
Think time. With no motor and a desire to drive the car, something needs to be decided on. Which motor???
Thought process.
A. Big block/ small block?
Quite easy really. The mind says blown bigblock. The wallet says blown small block.
Why?
1. Both the car and the old motor were built for each other. The front chasis rails and x-member have been made to suit a small block, that is, the room allocated when the EB column and rack was installed allowed a small block with a gear reduction starter to fit in, just. I dont want to cut into the engine bay to modify mounts ect.
Also all the front accessories (pulleys,water pump, alternator, power steering pump, manifold, sump, blower drive and dizzy) have all been custom fabricated to get a neat package and get the blower under the bonnet, this would be very expensive and time consuming to redo for a big block.
2. Can't legally register a blown 429/460 in NSW in a car with an original weight of 1550 Kg ( largest is 358cid if you were wondering).
3. Dont have a core engine.
Answer SMALL BLOCK.
B. Which small block?
1. 351 Windsor or 351 Clevo?. Windsor, superior parts availability, better oiling system, front accesories dont fit, dont have one :
2. 351 Cleveland. Poor block integrity : , Ive got a spare block, all parts fit, engine bay doesnt need mods, familiar with build up ( Big blocks are just big Clevo's IMO), Cost effective .
Answer CLEVELAND BASED.
C. Which Cleveland block?
1. Stock Ford Casting. Ive got one, they can be toughened up
2. World/Dart/Ford Motorsport/Man-o-war. All good, but the cleveland versions of these motors all use a windsor front structure, same issue with accesories, plus they are about $3000. :
3. New Alloy block. Bloke in the USA is casting alloy clevo blocks ( as well as cast iron), Light, new, exiting . Unknown durability, unknown delivery, not machined for lifter bores, cam tunnel ,decks, or finish mains tunnel, so factor in a few thou for the machine work, plus freight plus insurance plus the original price of about $2600 US. :
Check out this....
http://351cleveland.wetpaint.com/pag...e+Block?t=anon
Answer , STOCK BLOCK CLEVELAND.
All this of course is IMO. The new motor needs to have some sort of cost containment, its not going to be an all out drag motor, nor is it going to be stock with a blower, but you need to keep in mined what is its REAL usage...
Nuff of the dribble.
Some shots of the new block, some basic cleaning up of the block has allready been done before the shot were taken. Its a 74 model block to meet emmission rules and is virgin bore. Its done approx. 280,000 Km.
The block has been hot tanked and pressure tested. It was then sonic tested for bore thickness ( I have the report somewhere but cant find it for scanning), this showed 2 cylinders to be marginal thickness. All other cylinder checked out OK. The 2 cylinders were then sleeved. Then a rough bore was done to find out piston size.
A .010" bore wouldn't have cleaned up, so the block has been bored .017" ready for a hone to match each individual piston when they are bought. The main and cam tunnels checked for straighness. The block has not been decked due to not having rods and pistons for deck height.
You will also see that the valley is cleaned up of casting flash, and the outside of the block is die ground and sanded smooth. The inner part of the block will get the same treatment as the valley, just in case some debris is dislodged and jams the oil pump. The heater hose fitting has been removed and has been tapped for a 1/2"npt fitting.
As a side note, I machined the old motor myself when I worked for a large (government) company with the correct machinery ( Im a Fitter/machinist by trade), but since then Ive changed jobs twice and dont have this availability now. As a result Im using Westend performance in Sydney for all the machine work. They are close to work and home and I know they do good work cause I used to work for them in the early 90's ( read 1990).This isnt a plug just info!
And yes I know it only a two bolt mains job, but cost is an issue, thinking about a main gridle if it will fit in the sump.
Well thats it for the moment. Next time, engine components and configuration....
Cheers,
Gary.
Old 30-05-2008, 10:54 PM   #18
MEANXBCOUPE
cheers..
Hi,
The original block was in fact a 302 clevo. The crank and rods were 351 items, a very commom swap. That block was bored 0.030" ( say "30 thou") oversize.
A 460 would be nice, but due to local laws a 351 is close to maximum. ( ilove big blocks, my brother has a 429 in an XW ute and a mate has a 429 super cobra jet in he's XB coupe)
Hope this helps...
Gary
Old 30-05-2008, 10:58 PM   #19
MEANXBCOUPE
Hi Fev,
Yep doing heaps different, but you'll have to wait and see!!!!
The old motor had a stock cast crank, stockish rods, fordged pistons and 2v heads. Things will change for the new motor, mainly for reliability and a few more neddies.
Gary.
Old 30-05-2008, 10:58 PM   #20
MEANXBCOUPE
Ohhh, Cold beer you say????
Old 30-05-2008, 11:50 PM   #21
Auslandau
Auslandau's Avatar
Didnt know that! Wonder what the limit here in Vic is!
Great write up! Makes total sense to go back to the clevland block since you have most of the top end anyway ..... unless you are changing heads etc.
| [/url] |
Clevo Mafia
[SIGPIC][/SIGPIC]
Old 31-05-2008, 01:32 AM   #22
motorcycles4eva
love the xa's
good info ..thanks for that..
cheers
Old 31-05-2008, 11:05 AM   #23
Falcon Coupe
Clevo Mafia Inc.
Cheers,
Gary.
I had mine tapped for four bolt, it was pricy and while the caps are stronger more holes in the block are not really a great idea.
Looking at the webbing i reckon a main girdle would be a great idea.
Old 01-06-2008, 05:45 PM   #24
MEANXBCOUPE
Yeah, Im going the girdle, the motor is a little bit further on than the thread so im sorting that out now. Looks like I'll need to make one from scratch to fit in the sump. Just another custom part I guess!!!
Old 02-06-2008, 06:45 AM   #25
Uncle Raggy
Would it be easier to custom make a sump to fit around the girdle?
Old 02-06-2008, 08:49 PM   #26
MEANXBCOUPE
You havent seen the sump yet!!!!
Its been cut to lower the motor, so it clears the crossmember, notched to clear the rack, and winged to add extra capacity.
We'll see, as I said, kind of working it att out now.
Old 03-06-2008, 05:53 PM   #27
Rebel220
NSW Coupes Rule
Rebel220's Avatar
Colin... he is not to have beer when working on the car...I've seen what happens when he has had too much to drink and works on the car.
Ask Gary about the time he was making extractors for the car? Lets just say beer fridge in garage and welding is not a good mix!
I will never let him live that down...
Sorry Gaz, I couldn't help but mention this.
Greens Tuff
Rebel220 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2008, 10:22 AM   #28
Uncle Raggy
Ah, do tell!!!
Old 04-06-2008, 05:46 PM   #29
fatasslandau
the money box
FINE THEN I will have to bring scotch,burbon etc.......... and a little beer. Hey i also said i would bring the bubble wrap
Old 04-06-2008, 06:16 PM   #30
MEANXBCOUPE
Speek when your spoken to ,woman. :
