Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 13-06-2008, 10:40 PM   #1
freak6
superlow
freak6's Avatar
Default EF brake upgrade
hey mate i have a 95 EF fairmont which i need a quote to upgrade brakes on.
i need a set of 330mm front rotors and 300mm rear rotors with calipers to suit so i can get the car registered with the new motor.
look forward to a reply.
thanks sean
freak6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2008, 11:15 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
thanks sean
The front kit which is twin piston calipers and has 330mm slotted rotors is $2200 with exchange uprights but on the rear they have a 299mm disc anyway so just fit slotted rotors and better pads which would be from about $300 to $500 depending on brand.The front kit takes 2 to 3 weeks to put together thanks
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 16-06-2008, 07:36 PM   #3
freak6
superlow
freak6's Avatar
cool thanks for that mate.
so i just send the uprights over once i receive the new set up?
will i have more clearance for tyres with this setup?
at the moment my 19s scrub on the uprights by a few mm?
Old 17-06-2008, 10:34 AM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The offset isn't changed so they will still rub but on some occasions where there is a grease nipple hanging out of the top ball joint the tyres will rub on that so they have to be removed and put plugs in.
MATTHEW PEARCE
Phone 02 9609 1101
Old 17-06-2008, 07:47 PM   #5
freak6
superlow
freak6's Avatar
yer they scrub the ball joint up top. thanks for the info mate ill be in touch very soon.
Old 18-06-2008, 02:38 PM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
No worries
MATTHEW PEARCE
Phone 02 9609 1101
Old 26-07-2009, 10:15 PM   #7
FPVGT0
FPVGT0's Avatar
Will the 330mm brake upgrade fit inside the standard 15" alloy?
FPVGT0 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2009, 10:39 AM   #8
a-total-tool
a-total-tool's Avatar
It will not fit.
You will need at least a set of 17" wheels to clear the discs/calipers.
a-total-tool is offline   Reply With Quote Multi-Quote with this Post
