03-08-2008, 09:56 PM | #1 | ||
Have Boost, will use it..
Well, our trusted Caltex Servo just down the road has closed, and a new "Freedom" servo has opened up.
Only thing is, it only has e10 unleaded, e10 Premuim and Diesel. Has anybody used this e10 Premium? What octane level does it have? |
03-08-2008, 10:09 PM | #2 | ||
Teh Baest
Freedom fuels sell Unleaded Elite (95 octane-E10) and Premium Elite (98 octane-e10)
Never used it tho http://www.freedomfuels.com.au/fuels.html
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
03-08-2008, 10:45 PM | #3 | ||
149 rwkw of Style
change servos Sam
2004 XR6 Mercury Silver |
03-08-2008, 11:53 PM | #4 | ||
Taxman
As you can gather from my user name I am more a home with a computer keyboard than a set of spanners. My mechanic advised me to be very carefull with ethanol additives. Apparently he is of the opinion that some of the plastics used in fuel systems of some cars are easily disolved by ethanol and as a result there is a real risk of the electrics in the fuel system causing a vehicle fire. He suggested that we (5 drivers and 4 cars in the family) check with the different manufacturers for compatability with ethanol prior to using any, otherwise we could have a major problem.
04-08-2008, 04:28 AM | #5 | ||
IWCMOGTVM Club Supporter
Ring 13FORD if your worried, but it says all Falcons from 1985 can run e10. The BA ran it for 18 months and ran better then on non e10 petrol.
Daniel |
04-08-2008, 08:59 AM | #6 | ||
Wait? What?
I've been getting ok results from e10 95. However last week I had half a tank left of e10 and filled it up with regular 95 and it ran like a dog with terrible economy. No idea why. It feels the same on Ultimate 98 as well though. Bad economy and poorer driving feel.
04-08-2008, 03:36 PM | #7 | |||
Seriously speaking, mixing E10 and non-alcohol blended petrol will promote phase separation from all that water absorbed by ethanol. Petrol in presence of separated water will have lower octane rating. You can get a lot water into your tank if you often run on half-empty or less tank with long intervals between refuels. |
04-08-2008, 03:42 PM | #8 | ||
Tribal Elder
Tip a bottle of metho into the tank, mixes with water, end of story.
04-08-2008, 08:17 PM | #9 | ||
Mad Scientist!
I've been running United E10 (i think it's 95RON) for the past yr, And doing the calcs from km driven to L put in, there's a small decrease in L used per 100km and this is from a car that the web site suggests not to run the fuel. I have also put the United 98E10 in but as there was no real diff, couldn't justify the Xtra $$.
04-08-2008, 08:37 PM | #10 | ||
Oo\===/oO
I never see E10 of any form available...always have them crappy tags on them
04-08-2008, 09:50 PM | #11 | |||
King of the Fairy's.
With only 10% Ethanol you should be safe.
04-08-2008, 10:12 PM | #12 | ||
5.8 litres of fun
i use 95 ron e10 in my 95 fairmont and it runs fine.using normal unleaded etc doesnt make it run any better so i just use the 95 ron e10
2003 RTV 2015 Ranger XLS mk2 |
04-08-2008, 10:32 PM | #13 | ||
Living in GT Nirvana
You need to check your vehicle is E10 compatible just to be sure. Higher levels of Ethanol (ie higher than 10%) can dissolve rubber components in your fuel system unless they are specifically designed for >10% ethanol.
Main prob with ethanol fuels is its water attracting ability. Do you really know how much water is building up in your servo's E10 fuel tanks, particularly older tanks? |
04-08-2008, 10:46 PM | #14 | |||
Performance moderator
98% ethanol...
04-08-2008, 10:55 PM | #15 | ||
The Guy You Love To Hate
Does anyone know if / when they are going to be releasing E85 here?
I would love to get some of that stuff in my tank. |
04-08-2008, 11:01 PM | #16 | |||
04-08-2008, 11:05 PM | #17 | |||
Mustve missed that thread. Do you know approx when it will b released in Vic? Its for a turbo motor which ill be upgrading the fuel system for anyway, so it isnt an issue to run it for me. |
05-08-2008, 12:07 AM | #18 | ||
http://www.unitedpetroleum.com.au/media.asp?pgID=203
it has already been released in this country, problem is that there isn't that much around. But apparently Holden is releasing an e85 vehicle. http://www.flexfuelkit.com.au/articl...den/Page1.html
Daniel |
05-08-2008, 08:04 PM | #19 | |||
FG XR6T trayback
05-08-2008, 08:19 PM | #20 | ||
I saw an E80 or E90 car driving around Canberra last time I was there. Damn that must be cheap to fill up
When I had the TX5, I was running it on regular 95 and United E10 95 (moreso E10) - it was doing a bit better than regular 91 and on par with 95, but then the fuel pump died :\ I've started putting Mobil E10 in the Fairmont and when I come across a United servo (the one near my closed), I'll try out the E10 95 again... not that I use ULP any more as I've got LPG Back to the original question, E10 95/98 is fine, but TBH, I don't trust 'Freedom' servos.
2009 LV MkI TDCi Focus Hatch |
05-08-2008, 08:41 PM | #21 | ||
B E-S
Pretty simple, dont skimp out a coupla bucks on a full tank for ethanol.
You might save a couple of $$ - like 2, but you'll soon notice the kms out of a tank are not what they used to be.
B E-S |
05-08-2008, 08:52 PM | #22 | ||
Yeah obviously fuel consumption is higher, but it has a higher octane rating.
Tune your motor for ethanol= more power. From what ive read, those that are using it have reported that the fuel consumption negates any cost savings you might have with the lower price, but it is basically a cheap race fuel and has more benefits for a performance car. Last edited by T_Terror; 05-08-2008 at 09:03 PM. |
06-08-2008, 01:57 AM | #23 | |||
The guys here that have tuned their cars to run on E85 are struggling to get the same results they would on PULP anyway. Its not showing great results. Higher octane doesn't necessarily mean more power. |
06-08-2008, 03:06 AM | #24 | ||
Just slidin'
Have used the 95 and 98 for nearly three years, never had a problem, in fact I think they are great, I make good power from them, they dont pingon my generic tunes, they give good times at the track and I still get 600-700 k's to a tank.
MD Mondeo - For the family
06-08-2008, 09:36 AM | #25 | ||
Wow, some very different views.
To be safe though, I think that I will stay away from it.... |
06-08-2008, 11:04 AM | #26 | |||
Fast Ford to the Future
I haven't used standard (non-ethanol) fuel in my car for a few years now. My parents have been using ethanol (e10) on their falcon for at least 8 years now..North Queensland has had it for quite a while longer than other places. I've seen no ill side effects and economy is the same if not better than some other blends out there (depends on servo).
CURRENT RIDE - 2011 FG XR6T Nitro 6sp Manual with Luxury Pack, 19 Inch Varrstoen 2.2.2 Matte Black, Herrod Intake
OLD RIDE - oZeCruiser: 1994 ED Falcon Futura |
06-08-2008, 12:12 PM | #27 | ||
Just on a side note....I think that I saw you on Saturday FordAce. You were coming from the Alderly round about heading into town.
I was beside you and behind for a fair bit. I was in the wife's white Lexus however. The Siciliano sticker got my attention. |
06-08-2008, 12:20 PM | #28 | |||
Ethanol at up to 20% blend is fine for our cars (anything post 1985). In higher concentrations, like E85, that's where you need special fuel system components to cope with the effects of ethanol on things like plastics and rubber.
06-08-2008, 12:20 PM | #29 | |||
First time I've been spotted I think. Give a wave next time.
06-08-2008, 12:55 PM | #30 | ||
running 100 octane that uses 5% etho, the XR runs like a dream. I've said this on another thread, the car is a delight to drive. Response is better and overall a lot smoother. I believe it has something to do with advancing the timing given the higher octane. Only thing is at 189cents a litre, I cant justify it. It was bad enough at 159 cents. Oh and this price is fixed, doesnt change like all the other fuels. Guess its cause its the only 100 octane on the market.
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
