Old 08-09-2008, 11:16 PM   #1
LUV DE COUPE
LUV DE COUPE's Avatar
Default Tips on changing coolant xr8 series III
Hi I need tips on how to go about flushing and replacing coolant.How many litres does the system hold things to watch out for.
Thanks
LUV DE COUPE is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2008, 11:54 AM   #2
bloggs24
All i did was take out the fan, unplug the bottom radiator hose, plug it back in fill with clean water and some kind of radiator flush, let the car run for 30 minutes, wait till cool, empty from hose, and repeat until water comes out clean, then fill with new coolant. i think the capacity is about 15 litres, but there will be about 5 litres remaining in the system.
This is just what i done, but there is probably a better/proper way
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2008, 12:17 PM   #3
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
nothing wrong with what you have done bloggs24, it'll remove all large scalling, but there is another method of removing the small hose that goes from thermostate housing to water reservoir and running engine with hose in water res, and thermostat house hanging out of engine and letting it clean itself out, I'd normally do what you have done and then do this to clean out all remaining, water.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2008, 12:19 PM   #4
olfella
Cranky old bastard
That is how I would do it adding turn the heater up to full to flush out that side of things..
olfella is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2008, 01:44 PM   #5
InfernoSR
Sales Representative
InfernoSR's Avatar
Have a search for my DIY tutorial...
