Old 18-12-2008, 06:27 PM   #1
burnz
VFII SS UTE
burnz's Avatar
Default hsv direct inj lpg
hsv has a newie for the new year with direct injection gas v8 duell fuel and DOD
http://www.goauto.com.au/mellor/mell...2575210021F9AB
GO SOUTHS
burnz is online now   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 07:03 PM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
Is this going to be another media release where latter they don't come up with the goods...
Daily driver GTE FG..
Old 18-12-2008, 07:12 PM   #3
burnz
VFII SS UTE
burnz's Avatar
is HSV going green ???
GO SOUTHS
Old 18-12-2008, 07:27 PM   #4
Jack91
Jack91's Avatar
Sounds like a good idea, I like the idea of it switching to petrol when you boot it. I dont follow LPG at all though so that could have been around the last 5 years. Would holden australia have the capacity to convert all these engines themselves or would chev/GM have to give it the ok and make it over there for them?
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 07:27 PM   #5
T3ts50
T3ts50's Avatar
Apparently. They are also have a few Diesel mules going about. One which is a BMW turbo diesel. They will confirm the diesels in April next year. They are also hoping to bring out the Corsa VXR and a the Insignia VXR from Europe. So it does sound like they are trying to go green.
T3ts50 is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 07:35 PM   #6
Gobes32
Gobes32's Avatar
Holden/HSV have a history of announcing projects before they are given the green light. It's funny really because Ford OZ will beat them to having that same gas system fitted to Falcons. But nobody knows that because Ford don't make a song and dance about everything they work on or develop.
Gobes32 is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 08:04 PM   #7
prydey
Rob
prydey's Avatar
'new technology that you can't get in the aftermarket industry'
yeah, they really did their research on that one. I'm tipping the guys at ALPGW might beg to differ.
they don't actually say what sort of injection it will be. considering it says direct injection i'd imagine they are referring to liquid injection. i'd be mildly amused if this you beaut technology of theirs turns out to be vapour injected.
Old 18-12-2008, 08:13 PM   #8
Gobes32
Gobes32's Avatar
When you go to a lpg place to put your e series on gas, you have two options, the old gravity fed vapour system for around $2600 or liquid injection for around $4500. The second option starts the car on petrol and then when it gets to a nice temp it switches to gas, if you just cruise or light acceleration it will remain on gas, if you boot it or are towing or going up a steep hill then it switches back to petrol. Liquid injection supposedly does not backfire, blow the airbox up(lol) or lose much power because it goes through the injectors and not a "mixer" as such.
Rumor has it that the I6 will be offered as liquid injection shortly as it qualifies as a "green" motor under Ruddy's plan.
Old 18-12-2008, 08:15 PM   #9
bodes-sh
so is the current motor direct injection or not? i'm assuming if their lpg system is in fact direct injection and not just standard sequential injection then they have redeveloped the entire top half of the motor...?
edit;
Originally Posted by go auto
The dual-fuel system automatically switches from LPG to petrol under engine load to ensure it delivers the kind of performance expected from a muscle car.
The system starts using petrol and then switches to LPG. When the driver presses the throttle hard, the system quickly switches back to petrol for the best possible performance.
Mr Harding said the LPG system had passed the first test: performance delivery.
hmmm, obviously not liquid injection then...seems like good old svi to me
Old 18-12-2008, 08:17 PM   #10
bodes-sh
you have that wrong. the options are mixer or vapour injection. not liquid injection. liquid injection doesn't change over after a certain temperature, it has a set purge time to get any lpg vapour in the fuel lines out, then it changes to lpg. also, liquid injection doesn't need to switch back to petrol because it uses the petrol ecu to control the gas injectors and has it's own pump to keep the pressure constant. the only time it changes back to petrol is if you run out of lpg...
Old 18-12-2008, 09:17 PM   #11
Gobes32
Gobes32's Avatar
Sorry, If you can't already tell I don't have lpg.........But I only got the names Wrong???????
Old 18-12-2008, 09:26 PM   #12
bodes-sh
didn't mean to sound like i was having a go at you...i didn't know you didn't realise the difference...sorry
Old 18-12-2008, 09:55 PM   #13
Buzz Box
Wheel Wally
Buzz Box's Avatar
Either way its seems interesting but it stinks of mouth before money......
Buzz Box is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 10:00 PM   #14
GTP-814
love the quad cams
Why would you come to expect anything else from holden.
I also read thta they are talking of a V8 diesel with the same KW as current 307's. Fact or fiction
GTP-814 is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 10:01 PM   #15
MAD
Petro-sexual
MAD's Avatar
Interesting comment this one. I guess they havetn researched that much or they would have seen that the XR6 turbos that have been fitted with liquid LPG injection have actually had a small increase in power.
Good to see the most abundant fuel in aus getting some media attention and usage out of more factories.
Interesting how HSV have changed though, I remember back in the day were trying to discredit Tickford for fitting LPG systems. My how times have changed since that tool left the top job. Next they might even try to hot up a 6cyl heaven forbid.
- The Story
Old 18-12-2008, 10:01 PM   #16
naddis01
naddis01's Avatar
Are the LS3s direct injection, because there are rumours around that there are direct injection liquid injection systems (as opposed to normal liquid injection) being developed, but I beleive these can only be fitted to direct injection engines. If its not a direct injection liquid injection system then it cant be too much different to any systems on the market now.
No matter what sort of system it is, if it delivers the goods, I beleive it can only be a good thing and might dispell a few of the myths out there on LPG which to me is the most underrated fuel in this country. Now if only Ford could bring out a decent liquid injection system and finally pension off the prehistoric Egas system.
naddis01 is online now   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 10:06 PM   #17
ltd
Force Fed Fords
ltd's Avatar
Fiction.
When they find out what it will cost it will disappear just like all of Holdens big plans. Remember one thing, GM are set to go bust and they don't have any diesels like that in their stable, so Holden sure as won't have an engine option. Methinks that the lads in marketing have confused December with April the 1st.
Oh, and Daewoo have no such Diesel engine either.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 10:54 PM   #18
Bossxr8
Peter Car
Bossxr8's Avatar
Just remember the Commodore Hybrid will be released next year.
How many HSV loving bogans would care about the environment, probably none, the only benefit they would see would be in cost savings, but considering petrol is relatively cheap at the moment and anyone who can afford a HSV probably wouldn't have much trouble paying for fuel, i'm not sure if it will have a high take up.
Old 18-12-2008, 11:38 PM   #19
deesun
deesun's Avatar
But because it's Holden and in Drive, 99% of people will think its the latest and greatest,coughbullshitcough.
igodabigblackshinycar and I relented and allowed a BMW into the garage.
deesun is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 11:58 PM   #20
GTpilot
FG GT 5.4 w/ additions!
GTpilot's Avatar
“If you drive it flat-out on full throttle then you probably wouldn’t see any economy improvement,” Mr Harding said.
Mr Harding obviously does not know the average HSV buyer very well. From what I see they are either 100% go pedal or 100% stop pedal. This being the case, I can't see many HSV owners saving much $$
One a brighter note,
Can't wait for Tandbag to crash one of these LPG puppies at Winton, I'll be right there toasting some marshmellos
GTpilot is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2008, 02:34 AM   #21
FGX-351
Supercharged Mang-mobile
FGX-351's Avatar
XU6 FTL lol
09/00 VX HSV XU6 Build #0001 of 0171
http://fordforums.com.au/showthread....09#post5571209
-- Best E/T: |14.982 @92.12mph | R/T:0.013 | 60' 2.213| 330: 6.283 | 1/8: 9.624 @ 73.17mph | 1000: 12.529 | 25Deg, N/A Hum, 1010mb | Willowbank Raceway 7/12/16
Tickford EL Falcon XR6 RIP
-- Factory Manual
-- Best E/T: |14.991 @ 92.71mph | R/T: 0.607 | 60': 2.215 | 660': 9.665 |13Deg, 86%H, 1024mb, 184RA @ Willowbank Raceway
FGX-351 is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2008, 06:48 AM   #22
prydey
Rob
prydey's Avatar
the only reason ford are still going with the mixer setup is because they locked themselves into a supply contract with vialle (or something to that effect).
it may be older technology but it is well sorted and serves the purpose for which its designed. taxi's love it because of the very low service costs.
i have one (bfmk2) and i'm more than happy with it. still ample power for a family wagon and cheap to run.
Old 19-12-2008, 07:47 AM   #23
whales
351 Cleveland:Pure Muscle
whales's Avatar
So true about Ford not making a song and dance but perhaps they should
whales is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2008, 08:03 AM   #24
burnz
VFII SS UTE
burnz's Avatar
Originally Posted by ltd
Fiction.
detroit diesel ~ allison, is gm diesel division
i am shure thay will have a series 30, 40, type engine available, whether hsv get them is a different story.
GO SOUTHS
Old 19-12-2008, 08:03 AM   #25
Gobes32
Gobes32's Avatar
Maybe they are worried about looking stupid when the project gets canned, there was a diesel territory getting around campbellfield when Polities was in charge. However not many people knew because it was only a feasibility study. They didn't hold a press conference etc like Holden seem to.
Old 19-12-2008, 08:06 AM   #26
LTDHO
The one and only
LTDHO's Avatar
Hrmm, is this another thing Holden/HSV do and Ford/FPV don't?
If FoMoCo had half a brain, they would have already devoloped an FPV on straight LPG injection. Rid the patrol tank, cat's etc and make a real moster that is realitively cheap to run.
But Noooo!
Tuned by CVE Performance
Old 19-12-2008, 08:15 AM   #27
burnz
VFII SS UTE
burnz's Avatar
But Noooo!
i've allways like the potential of lpg's 115 octaine,
but if gas only you are very much limited to city area's, go country you may have no gas.
GO SOUTHS
Old 19-12-2008, 08:27 AM   #28
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Easy enough to find where they are:
http://www.nowwhere.com.au/lpga/planner/default.aspx
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2008, 08:46 AM   #29
whales
whales's Avatar
I thought GM off loaded Detroit a few years ago
Old 19-12-2008, 12:45 PM   #30
prydey
Rob
prydey's Avatar
not so much these days. in my case i have a bfmk2 egas wagon which on the highway will have a range of close to 1000km. if i can't find gas somewhere in that time then i have larger issues at play.
LTDHO - ford may well have a svi or li lpg system ready to go. like i mentioned earlier though, they can't implement it just yet due to supply contract with vialle.
