Old 28-03-2009, 12:26 AM   #1
GTENVY
GTENVY's Avatar
Unhappy HELP - 94 subaru liberty problem
Hi guys,
my wife has a 94 subaru liberty which has got 260kms on the clock. The engine idles rough on start up most times (but not always) and after acouple of minutes or sometimes 20 seconds the idle smooths out and the car runs fine till you stop it then start it up again. Any ideas guys.
Thanks in advance.
FM Mustang GT, manual - Daily driven
Live, Love, RACE
SOLD: AU III XR8
Originally Posted by nstg8a
cars are to be driven, ornaments are to be looked at. the two should never be confused.
GTENVY is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 12:36 AM   #2
escapin
escapin's Avatar
mine used to do the same thing had 213kms on it
was the o2 sensor. well that was my fix any way
escapin is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 12:40 AM   #3
HaZ-R-DuS
HaZ-R-DuS's Avatar
Could even be the Air Flow Meter. Subys are known for them failing.
HaZ-R-DuS is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 12:50 AM   #4
GTENVY
GTENVY's Avatar
righto guys, thanks for the tips, we'll have a look see and let you know the results.
Cheers fellas
Live, Love, RACE
SOLD: AU III XR8
Old 28-03-2009, 01:25 AM   #5
xls3v
xls3v's Avatar
mine same problem but it was head gasket and bottom end bearings big dollars
xls3v is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 01:51 AM   #6
GTENVY
GTENVY's Avatar
'big dollars' isn't that with anything to do with subaru!!! lol. Should be bottom end as we had the engine replaced 10k ago as it blew up ( I kid you not). The replacement engine was from a car with 90k on the clock and was checked over, but they used the original air flow meter etc. Sorta makes sense as the car was doing it on and off with the old engine...
Live, Love, RACE
SOLD: AU III XR8
Old 28-03-2009, 02:07 AM   #7
xls3v
xls3v's Avatar
gotta love the timing belt too like wtf 400-800 depending were you go
Old 28-03-2009, 11:30 AM   #8
VioletGT
Slow Sunday driver
VioletGT's Avatar
i would try a tune up... plugs, all filters and o2 sensor 4 sure...... could even inspect the throtle body for gunk around the butterfly
VioletGT is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 12:56 PM   #9
LOCO XP
LOCO XP's Avatar
if that fails, increase 0xygen by adding 2 turbos. more boost fixes everything
LOCO XP is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2009, 01:10 PM   #10
escapin
escapin's Avatar
yeah my radiatior blew the ends out and cooked the head gasket.
total rebuild stronger and ported and polished heads, cams, went heaps harder was a great car.
Old 28-03-2009, 04:35 PM   #11
GTENVY
GTENVY's Avatar
Nice, like your thinking : But I wanna spend some $$$$'s on the sprint first :dr_Evil:
Besides she's eventually wanting a liberty GT by STI :
Live, Love, RACE
SOLD: AU III XR8
Old 28-03-2009, 08:13 PM   #12
Matty4
Banana
Matty4's Avatar
Yep......couldn't agree more, see sig.
I agree with the thought of it being the AFM. I had to replace mine around the 90K mark as it was hesitating a fair bit at low engine speeds and would then clear up after speed increased. Not a huge price for one of these, $90 for mine IIRC.
Matty
2024 Ford Ranger Wildtrak V6 w/PP
2012 WK2 Jeep Grand Cherokee Overland CRD
Matty4 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2009, 11:21 AM   #13
Quicklier
Perfecting the 1-2 change
If it's idling rough for a few minutes I can't imagine it's going to be an O2 or AFM (Air Flow Meter). If it's rough (shakes the car a bit) it is likely to be a breach in one of the head gaskets allowing watter from the water jacket get into the cylinder. It won't happen all the time as the breach is probably only very small.
A fairly easy way (well, not in a lib) would be to start it, let it idle rough for 30 seconds then shut it down and start inspecting the spark plugs. If you find a wet one, you've found the leak.
And if it IS the issue I've described, if left unchecked you'll have 3 good pistons, and 1 buggered one.
MY02 Subaru Forester GT
XC Fairmont - Project Thread Here
Quicklier is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2009, 02:07 AM   #14
GTENVY
GTENVY's Avatar
Well Quicklier, you were correct. Its the head gasket and I have been quoted $2 grand plus to fix and three weeks down time. Looks like she's going to the wreckers :gren:
Live, Love, RACE
SOLD: AU III XR8
Old 18-04-2009, 08:03 PM   #15
ChemicalHorizon
How strange, this is the third subaru iv heard in a week with the engine going completly, then the "new" recond engine having problems within a short time....
ChemicalHorizon is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2009, 09:26 PM   #16
V8falcons
V8falcons's Avatar
If you are going to keep the car remove the gen 2 ,2.0 or 2.2ltr and fit a gen 3 2.5ltr single overhead cam engine all the head gasket issues were sorted with this engine and will not give you any troubles for the the next 10 years!!!!!! so long as the timming belt is replaced at correct intervals
Not to mention more tourqe and a fairly straight forward conversion.
You should find one in an import wreacker for less than $1000.
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2009, 11:05 PM   #17
GTENVY
GTENVY's Avatar
Its all a conspiracy I tell you :dr_Evil:
Live, Love, RACE
SOLD: AU III XR8
Old 18-04-2009, 11:13 PM   #18
AllCoupedUp
Garage Dreaming...
Location: In the garage - waiting for the car to build itself!!
Tell her to get one - I've got a GT-B and it rocks!
Can I say that in a Ford forum?? :
AllCoupedUp is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2009, 11:28 PM   #19
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
You replaced the motor on a 94 subaru? Why? You liked paying exorbidant costs for a thoroughly average car and couldn't bear to stop?
Old 18-04-2009, 11:54 PM   #20
vanman_75
XD Sundowner
vanman_75's Avatar
i had same problem ,ended being 2700 by the time it was fixed as so many other things need doing to change gaskets ,then i traded it for 1700......lesson learned
something old something blue
vanman_75 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 08:34 AM   #21
CPOCSM
Head gaskets are fairly simple to fix and with the Subarus, the biggest pain in the bum is the setting of the timinig again...really needs 2 people - one to set the timing and the other to get your tools when you fling them up the yard!!
Jokes aside - if the heads need to come off, do the following as well:
- Head gaskets (kind of a gimme)
- cam seals as they will need replacing the moment you put it back in the car!!
- Check the water pump - see the above comment!!
- Check all idler pulleys as the bearings can fail - even after low km
- replace the belt/s (the EA82 I have has 2 belts - double the price!!)
- DO replace the cam covers and dont leave them off for bling factor - murphys law states that something will get stuck in the belt
- Use the Subaru upper cylinder cleaner - it is fantastic and your car runs like a new one - it is an aerosol so be careful
- tappet tick is a fact of life in a Subaru - will not damage the car - just turn your stereo up to drown it out
- O2 sensor is a biggie but if you insist on buying them off fleabay, make sure that it is the right one
A good trick with Soobs too - when the car starts to burp and fart...disconnect the battery overnight as this resets the ECU and then drive it like you stole it. This "educates" the ECU and it sets itself up accordingly.
Have fun
Hooroo
CPOCSM is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 06:53 PM   #22
GTENVY
GTENVY's Avatar
Tried arguing with your wife lately???
Live, Love, RACE
SOLD: AU III XR8
Old 19-04-2009, 08:37 PM   #23
Mr Hardware
Yeah, sorry, i just can't stand people doing things like vanman 75 highlighted, spending $2k on a $1k car.
Old 19-04-2009, 10:16 PM   #24
GTENVY
GTENVY's Avatar
Totally agree, she has finally seen the light mind you, for the interim we picked up a 93 EB11 station wagon for $3000 with 100,000 kms on the clock. Only 2 owners and besides the odd car park scrap she is in pretty good nick :
Live, Love, RACE
SOLD: AU III XR8
Old 19-04-2009, 10:28 PM   #25
Mr Hardware
Yeah that's the way.
Mind you i'm no angel either. I have a total inability to send a car to the wreckers when i could fix her up and sell her, even if i'd make no more money than the $150 from the wreckers. But i make sure i'm not going to lose out of the deal either.
Old 19-04-2009, 11:58 PM   #26
vanman_75
XD Sundowner
vanman_75's Avatar
didnt have time to fix it ,so was forced to take it to a mechanic thats never worked on em and the list just kept growing as the job progressed ...like single use head bolts .lol it wasnt a 1000 dollar car when i owned it but i guess they are now .a good lesson is if its old get a basic car ,falcon commo etc ,if not get very low k or new if you can these new cars wont see 20 years plus with all the crap that can and will go wrong with em.
