Closed Thread
Old 30-03-2009, 06:41 PM   #1
MR.BA.GT.332
Now in the quad cam zone
MR.BA.GT.332's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all his work in the project section. Awesome effort.
Default Who here has ACTUALLY USED Procomp heads??
who here has or is running an engine with procomp heads?? doesnt have to be just ford either
im not starting a thread to bag out the procomp name and if you are going to talk junk about them then please take it to another thread, just curious to hear from people who ARE actually running them and what have their experiences been.
ive read and heard a lot from people who are quick to say bad about the name, but the comments are from people who HAVENT used the heads on their engines so i would only like to hear from people who are using the heads.
I know all about the stories regarding their dizzys etc.... but heard their heads are not too bad...
anyway, i'll await the replies cause people seem to be buying them so surely someone has something to say..
SOLD!"KELLY" 4/72 XA Futura Sedan, Black interior, 466ci Big Block, Tremec TKO600 close ratio, Wilwood 4pot Front Discs, Disc Brake 9 inch diff & 3.50 gears, F90 17x8 17x9 Polished Simmons
"BARNEY" 2003 BA GT #332, Phantom, Boss 290, FR20 Simmons. XYZ Brakes - 355mm Rotors - 8piston Front Calipers & 4piston Rear More Mods soon!!
MR.BA.GT.332 is offline
Old 30-03-2009, 06:50 PM   #2
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
A simple search would have found numerous hits.
http://fordforums.com.au/showthread....hlight=procomp
nugget378 is offline
Old 30-03-2009, 06:54 PM   #3
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
a friend of mine builds motors and uses their heads flatout, he says apart froma little tidying up they are excellent for a low cost engine build
yift is offline
Old 30-03-2009, 07:36 PM   #4
4VCLEVO
XA GT
4VCLEVO's Avatar
I run them on my clevo. Some problems such as shrouded valves, spring hights can vary slightly. You wouldn't use these heads without fixing the problem listed, and if your handy with the di-grinder then they are a good buy. I think now that AFD's are prety cheap, then you should buy those over the procomps.
I have them now and am happy enough with them, my engine is producing around 500hp, and happly cruises around at 1600rpm with a toploader and 3.7 diff gears, so I can't complain.
I'm sure if you do a search for procomp in the cleveland section then you'll find several posts about my experiance with the heads.
XA GT, 6.848sec 1/8 mile @ 101.68mph
4VCLEVO is offline
Old 30-03-2009, 07:37 PM   #5
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Originally Posted by nugget378
Agreed.
Falcon Coupe is offline
Closed Thread
