Old 07-07-2009, 09:32 PM   #1
nsgnomad
Question WP Fiesta manual gearbox oil change
Can someone tell me how to drain the oil from the gearbox and where the filler plug is to top it up again. I wouldn't normally do this but I need to replace the driveshaft oil seal. I can't see either a drain plug or a filler plug on this manual transaxle.
nsgnomad is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2009, 08:00 PM   #2
nsgnomad
Well I found out the easy way (expensive way).. I paid a mechanic to do the job then asked him where the filler adn drain plugs were. Both plugs are inside the plastic cover at the front of the gearbox. This has a clip on cover and is the cover over the gear change linkage. The filler plug has a hexagon shaped recess that you would need a special tool or the right size allan key to fit. The drain plug has a square end on it.
Old 03-03-2011, 10:15 PM   #3
baxt_turbo
i did my gear box oil change very easey to do, i dont know why u paid someone to do it all u have to do is look and use your brain, all u need is a allen key cant remember what size , a 19mm socket and a tom thumb(pump)
baxt_turbo is offline   Reply With Quote Multi-Quote with this Post
