Old 09-08-2009, 01:18 PM   #1
wmj73
Default Zetec light removal help
Hi Guys, newbie here. I just bought a Zetec and would like to change the colour of the main light to a more blue or white colour. I rang up Ford and asked what buld type the main beam was and they said it was H7. Went to the local autobahn bought a set of 5000k H7 bulbs. Problem that I am having is removing the main headlamp unit. I undid the 2 main screws and the 1 'tab' type screw and the electric cord adapter but it seems like something else is holding the unit down. Didnt want to pull it out with too much force but if anyone can give me some info I would greatly appreciate it.
wmj73 is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2009, 07:57 PM   #2
kiwijohn42
Death B4 Decaf
kiwijohn42's Avatar
You have the manual don't you? Should all be in there.
06 fiesta Zetec in Tango. Factory scuff plates, mats, spoiler & leather gear knob. K&N panel filter. Focus clear side indicators. Colour coded.
kiwijohn42 is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2009, 11:18 PM   #3
curik
Yep its in the manual, basically there are two torx screws and one plastic clip per headlight that you need to remove. Then remove the wiring and pull the headlight assembly away. Thats it.
curik is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2009, 11:40 PM   #4
dannyhilton
dannyhilton's Avatar
I'm interested in changing my bulbs too. I want more of a clean White rather than a yellow, but not too much blue like you see in Mercs. Can anyone reccomend anything?
Also is it illegal to change the fog light bulb to a matching White ray?
CURRENT: 2017 Escape Titanium 2.0L EcoBoost with Technology Pack in White Platinum
PREVIOUS 2015 Fiesta ST / 2012 Focus Titanium / 2009 Fiesta Zetec / 2004 Fiesta Zetec
dannyhilton is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2009, 02:25 AM   #5
curik
Go HIDs! They look sick even on stock projectors. Clean cut-off and way brighter at night! But if you want to stick with halogens, phillips Diamond vision or PIAA (can't remember the model name).
Old 10-08-2009, 06:29 PM   #6
dannyhilton
Thanks mate. I want to make my Projectors a brighter White. I'll invest in this on the weekend! Cheers.
Old 12-08-2009, 07:05 PM   #7
wmj73
Curik, are they easy to install and do they cost alot? Where did you buy them from too? thanks heaps guys for all the replies
Old 12-08-2009, 11:00 PM   #8
Fi.ES.TA
Fi.ES.TA's Avatar
wmj73 they are $101.00 off ebay.
Fi.ES.TA is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2009, 03:24 AM   #9
curik
as FiESTA says, the HID kit is about 120 ish on ebay and pretty reliable too. Installation was easy, but a slight modification of the bulb retainer clip is required. Apart from that, pretty straightforward and amazing result too!
