Old 10-09-2009, 11:09 AM   #1
black mamba
harsh but fair
Default coolant / radiator
anyone aware of radiators leaking and coolant mixing with trans fluid? - only noticed it today on my girlfriends 2003 BA. Despite new coolant being put in about 3 weeks ago, its now an orange colour. No point getting pressure test done on radiator, i'm sure it's leaking , just the color of the coolant worries me.
black mamba is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2009, 11:21 AM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Hey mate
you might want to put this in the b-series section rather than the AU one
and yes, there is a known fault with the b-series where the division breaks between the trans fluid and coolant in the radiator and can mean some very expensive work, most notibly new trans. Have it looked at asap and expect $$$.
Old 10-09-2009, 11:30 AM   #3
black mamba
harsh but fair
will do cheers. Doesn't sound good.
Old 10-09-2009, 07:28 PM   #4
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Getting more common every day now BA's are getting older
I have had it a few times, new radiator, new coolant, thoroughly drain tranny oil and you may get away with it like I did
Other people new gearbox
Speed is the key here
Is the gearbox playing up yet?
Jastel is online now   Reply With Quote Multi-Quote with this Post
Old 10-09-2009, 11:02 PM   #5
amiers
Sorry to hear that mate. had mine do the same, 2000 grand for a reco box. when you get it fixed put a remote trans cooler on it.
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2009, 08:32 PM   #6
Mechan1k
Mechan1k's Avatar
Or if you can ... see if you can get a BF setup where the transcooler is not inside the radiator ... and just the heatsink on the side of the engine block.
I much better setup indeed ... and you can still go an external trans cooler from there as well.
Old 11-09-2009, 10:44 PM   #7
InfernoSR
Sales Representative
InfernoSR's Avatar
Copper/Brass oil coolers in ADRAD radiators havent failed (to my knowledge)... the aluminium oil coolers let go to easily from the AU onwards...
My suggestion, upgrade the radiator (ensure you get a copper/brass trans cooler), and get the gearbox thorougly checked for possible damage.
Old 12-09-2009, 07:36 PM   #8
Jastel
BF setup not much different, can still leak water into coolant if you get a dud heat exchanger.
Keep inhibitor levels up in the water helps
My failures have all happened over 300000km so cant whinge about that
